Front width/offset question
Old May 30, 2011 | 05:10 AM
papo's Avatar
Default Front width/offset question
would a x10+20 clear the coilover in the front? with minimal camber maybe -3* in the front
Old May 30, 2011 | 06:52 AM
jeremydoc's Avatar
I have a 10 inch rim. +25 with about -2* camber. It clears just fIne
Old May 30, 2011 | 08:07 AM
jeremydoc's Avatar
didnt realize this was for xb. lols
Old May 30, 2011 | 04:37 PM
wolfsburg2k1's Avatar
I've got a 9" +35 with about -1.5 camber & no issues yet...
Old May 30, 2011 | 08:21 PM
papo's Avatar
I know a 9.5 will be fine but I want a 10 that's .5 less of inner clearance.
Old May 31, 2011 | 12:54 AM
CIONIDE's Avatar
It's actually only 1/4" less inner clearance, as long as the offset is the same for both wheels. The difference in wheel width (in this case 1/2") is split between the inside of the wheel and the outside of the wheel. So the 10" wide wheel will be 1/4" closer to the suspension, but also stick out 1/4" closer/past the fender.
Old May 31, 2011 | 01:21 PM
TruWil's Avatar
What issues, if any, will I run into going with 18x9 with an offset of 38? I'm only ginving it a 1.5 drop. (06 tC)
Old May 31, 2011 | 03:47 PM
CIONIDE's Avatar
Wrong forum... you're asking tC national questions, but in xB2 country.
Old May 31, 2011 | 03:52 PM
TruWil's Avatar
sorry just noticed that and was waiting to get "tore up", but thanks for taking it easy on me. ha
Old May 31, 2011 | 04:52 PM
Pasquale's Avatar
I was thinking the same thing popa. I need to pull my wheels off and start measuring. Let me know how it goes if you do it man.
Old May 31, 2011 | 10:09 PM
popfizzle's Avatar
I have 19x10 +25 pics from a mockup we did before I ordered a set of 35's for the front. without tires at stock height it clears everything just fine. That is of course with a 225/35/19.
I am about to drop the fitment pics from the BBerry to photobucket - I will try to remember to post a link.
Old May 31, 2011 | 10:24 PM
popfizzle's Avatar
Smile
this is 19x10 +25 all around. I later decided +35 for the front would be better as I had room for it.
sorry for the quality - it was a blackberry and yes those are dents. I have a SEVERELY hail damaged XB - it makes it easier to do crazy stuff if the car is paid for and already damaged. LOL
Old Jun 1, 2011 | 04:02 AM
Pasquale's Avatar
did you use any camber?
Old Jun 1, 2011 | 03:37 PM
popfizzle's Avatar
I have not as of yet. I will keep it updated though, as there is plenty of room with a 25 to clear the shock.
Old Jun 1, 2011 | 04:39 PM
Pasquale's Avatar
The thing im worried about is if you camber the wheel because I wouldnt want that much poke in the front would it still clear with -3. +35 compared to +25 is less then an 1.00" more back spacing. and -3 camber is going to bring that lip a lot closer. Keep us updated!
Old Jun 1, 2011 | 05:47 PM
popfizzle's Avatar
I will give you a for sure this week. I have 4 +25 and 2 +35's to try out. I am going to see what camber is needed for the look I am going for and will post pics of stock / cambered / insanely cambered to give you and idea of what this will look like. I am thinking the springs I am running will only be on for a short while since I may go air soon after I get this setup right. Or, alternatively I will go racelands when they are available.
Old Jun 1, 2011 | 11:31 PM
popfizzle's Avatar
so I got my Ksport GT's in tonight and they look legit. I will be putting them on tomorrow and snapping some pics of the setup if we can get the tires mounted. only problem I have right now is we don't have a balancer and need to put 235/35's on a 10 inch wheel. I may have them tomorrow though if I can convince my local guy to mount / balance. I also ordered shims to take it out a bit, not 3* yet - but that is coming.
Old Jun 2, 2011 | 04:07 AM
papo's Avatar
Yeah the wheels I want don't come in x9 unless I go with a 18/19 set up but I want to run 19s all around, that way I'll have a few mm of height clearance compared to 18"s so I can daily with out a problem on coils.
Old Jun 2, 2011 | 04:40 AM
papo's Avatar
as for the guy with the x10s all around i would of just ran camber in the front to fit the +25s.
Old Jun 2, 2011 | 09:16 PM
Pasquale's Avatar
same here if it worked. Papo word of advice tire prices suuuuuuuuck on 19's and without a kit the car looks too tall. If you want something to reference I can send you pics of my car without the kit all the way aired out. I really liked how your car sat with your last set-up.
