weapon R header problem
Old Jun 2, 2011 | 09:01 PM
skatenc123's Avatar
Default weapon R header problem
so after 4 hours of not being able to get the stock header off i sucked up my pride and took it to a shop took them about an 1.5 hours charged me 60 bucks super cool people. but now when i put the car in reverse and my foot on the brake its makes a really loud clicking noise and shakes pretty bad. But only in reverse not drive or neautal. any body have any ideas? maybe its something just hitting something else?
Old Jun 2, 2011 | 09:55 PM
BadDudeTC3's Avatar
I had some work done by my mechanic on my first exhaust system set up and he had to remove a bolt and reshape the heat shield to prevent the knocking sound. Haven't had a problem since....
Old Jun 2, 2011 | 11:29 PM
skatenc123's Avatar
howd the headshield prevent knocking. theres no place for the blackets on the weapon R headers and i also have skunk2 exhaust.
Old Jun 4, 2011 | 05:36 PM
BadDudeTC3's Avatar
When you put the aftermarket header on it will make the exhaust rattle more in reverse because the header isn't bolted down like the OEM header. My mechanic had to slightly adjust the heat shield because the exhaust was tapping the heat shield slightly. No matter what you'll get a little vibration in reverse, it's normal.
Old Jun 5, 2011 | 04:48 AM
Spicy_McHaggiz's Avatar
I've not had any "knocking" in reverse with aftermarket header. BadDude are you running the stock heat shield on an aftermarket header?
Old Jun 5, 2011 | 05:08 AM
XIEmperorIX's Avatar
Do you have a CAI? Those rattle in the frame were they go through...ou may just not ha enoticed it before..I had no issue with my weapon r header
Old Jun 7, 2011 | 06:16 PM
skatenc123's Avatar
yea i have a CAI but it wasnt the problem. the headers/s pipe moved my exhaust back about 1/4 to 1/2 inch which put the bolts on the exhaust right against the tow hook under the car so it was hitting it pretty good. cut the tow hook out. problem solved.
Old Jun 7, 2011 | 07:27 PM
GQQSE13's Avatar
ive got the weapon r header and mine will rattle sometimes as well but i've also got some custom work on it from when they put the resonator on so just assumed it was that but it occurs in reverse as well
Old Jun 27, 2011 | 05:14 PM
skatenc123's Avatar
mine was actuyally hitting the brace under the car so the bent it and put it back and also hitting the two hook connector underneath.
Sumtallguy
Mar 24, 2015 04:55 AM
stayintrucha
Mar 17, 2015 08:45 PM
sanders_scion
Scion tC 2G Forced Induction
Jan 20, 2015 04:54 PM
