Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
Headlight assembly removal?
Old Jul 2, 2011 | 03:02 PM
kvnhmmd's Avatar
Question Headlight assembly removal?
I was wanting to remove my headlight assembly, and realized that it was not as easy as I originally thought, because the bumper is in the way.
Does anyone here have any experience with removing the headlight housing?
My goal is to replace the factory projectors with HID D2S projectors.
Old Jul 2, 2011 | 03:50 PM
WellesleyScion's Avatar
you need to remove the front bumper, which is pretty straight forward. Once the bumper is off, then you will have access to the bolts at the bottom of the headlights.
Old Jul 2, 2011 | 04:47 PM
MightyP's Avatar
So... HID kit is available?
Old Jul 3, 2011 | 02:17 PM
kvnhmmd's Avatar
I was taking a look at this: http://www.theretrofitsource.com/pro...roducts_id=254
This way, I can replace my halogen projectors with HID projectors, and add a good quality 50w HID kit.
(This will also allow me to have 2 high beams)
To remove the bumper, is it just a few bolts and plastic pins at the top under the hood, and the rest underneath the car?
Old Jul 3, 2011 | 02:41 PM
Rotz's Avatar
Are you retrofiting your high beams or low beams? The stock projector lens already has a clean cut off line.
Old Jul 3, 2011 | 02:45 PM
kvnhmmd's Avatar
I'm not touching my highs right now.
Replacing my low beam projector with HID projectors.
And it's nothing to do with the cutoff line. There are pretty distinct visual differences between Halogen, and HID projectors.
I was simply noting that the HID projector I'm using to replace the halogen projector happens to be a dual high/low beam projector. This will allow the projector to function as high beam in unison with my stock halogen highs.
Old Jul 3, 2011 | 02:49 PM
Rotz's Avatar
I get you now. Well good luck with the fit. You better keep us posted with how it works out and pics of course.
S7ephavs
Mar 22, 2015 12:09 PM
Kata
Mar 2, 2015 10:46 PM
scsteven
Jan 25, 2015 01:06 AM
kleecker
Jan 9, 2015 02:26 PM
