easest way to remove srs airbag light
Old Jul 7, 2011 | 06:21 PM
jessetc's Avatar
Default easest way to remove srs airbag light
Hey guys Idk it there's a thread on this yet but I just want to make one for the guys that are annoyed with the srs light and don't want to spend the money on parts. this the most cost effective way to turn off the srs light. Your srs system will not work properly with light on so your taking your chance by not fixing it properly. This is only to stop the srs light from being shown on you cluster
After removing cluster take off clear cover and black trim on the front and rear plastic on the back side of the cluster
Remove needles with a fork
Then remove gauge cover
Cut a small piece of electrical tape big enough to only cover the airbag and stick it to the backside
Reinstall and your done
Old Jul 8, 2011 | 08:26 PM
GUNNIST14's Avatar
I wouldn't recommend this because this can be used against you if anything ever goes wrong. Tampering with safety devices and alert systems is a bad idea bro. Just letting you know. Fix it right the first time and you should be good.
randomsuper
Feb 4, 2015 10:13 PM
fur_pig
Scion tC 1G ICE & Interior
Jan 27, 2015 12:52 PM
toyotaisme
Jan 10, 2015 10:24 PM
