Tightening topmount of coilover (h&r)
Old Jul 18, 2011 | 09:21 PM
danny662boy's Avatar
Default Tightening topmount of coilover (h&r)
ok so the front driver side makes a clicking noise, whenever i give the car gas, while moving... if im parked or stopped and have the clutch in, and rev there is no click.. but the moment i start to move i hear like 2 metal clicks, then it stops.. but most likely i hear these little clicks while letting off the clutch and giving it gas ?? ive been reading posts that say to tighten the top mount of the coilover? is that on the top? side? where? pics please anyone... noise is driving me nuts
Old Jul 18, 2011 | 09:45 PM
yellowxhoodie's Avatar
If you dont know what your doing, take it somewhere that does.
If you do, tighten the top mount, which is on the top, hence why its called the top mount.
Old Jul 18, 2011 | 09:46 PM
Open your hood, tighten the bolts that hold the coilover to the body.
If you still dont get it google "coilover top mount"
Old Jul 18, 2011 | 09:50 PM
yes the center bolt correct?
Old Jul 18, 2011 | 09:56 PM
no, the outside ones, that attach the coilover to the car.
Old Jul 18, 2011 | 10:01 PM
thank you
Old Jul 19, 2011 | 06:23 PM
ok definately nothing on the suspension or boots, rods, etc. i just had it in for an inspection and told the mechanic to look at all possible areas and everything looked great and bolts were tight.. he said it might be some play from the aftermarket wheel? but it never sounded like that so im thinking it could be a bad lugs?
Old Jul 19, 2011 | 06:26 PM
Its very hard to diagnose sounds over the internet.
If the car was at the mechanics and he couldnt find the problem within the suspension he should have taken the car for a drive with you or let you drive while he rode along, while trying to replicate the sound so it could be pointed out to him and he had a starting point.
Old Jul 19, 2011 | 07:11 PM
he heard the sound when driving it in... and said that with aftermarket wheels they can make that noise
Old Jul 19, 2011 | 07:18 PM
I dont get how you can have play from an aftermarket wheels.
Check to make sure the wheels are balanced properly.
If you are not running hub centric rings and the hub bore of the wheels is anything diff than the OEM bore, get them.
Make sure lug nuts are seated properly and torqued to spec.
Make sure wheels are not bent or damaged in any way.
Old Jul 19, 2011 | 07:36 PM
hub centric rings?
Old Jul 19, 2011 | 07:39 PM
http://www.justforwheels.com/index.j...cat=hubcentric this thing?
Old Jul 19, 2011 | 07:54 PM
yes those are hubcentric rings but you will need to verify that they will fit your wheels. You need to find out the Hub bore of your wheels
Old Jul 19, 2011 | 08:06 PM
ok 72.6 is the bore of those rims.. now whats the next step?
Old Jul 19, 2011 | 08:31 PM
Find a ring that has a 54.1 Inner Diameter and a 72.6 Outer Diameter
Old Jul 19, 2011 | 10:18 PM
http://cgi.ebay.com/ebaymotors/Hub-C...ht_4615wt_1108 would this b them?
Old Jul 19, 2011 | 10:30 PM
yes
Old Jul 23, 2011 | 05:42 PM
ok put em on, still making noise... well atleast i wont have steering wheel wobble at 70 mph
Old Jul 23, 2011 | 05:44 PM
usafscion's Avatar
after you are done with the center bolt.... If I were you I would take the time to make sure the struts are all done correctly and re-check everything.. someone else posted the their bolt from their caliper felt off on the hwy while driving... that freaking sucks... dont want to be that person that say ____... I should have rechecked everything... while you are in the tow truckk... just my 2 cents... worth your time..
rvascion
Nov 12, 2020 03:23 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
rmz489
Sep 16, 2015 08:19 PM
ScionDP
Sep 8, 2015 02:17 AM
antayala
Sep 4, 2015 05:12 PM
