Alignment at Midas
Old Jul 19, 2011 | 01:13 AM
Xx AzN xX's Avatar
Default Alignment at Midas
ok so i just got lowered on skunk 2s a 1.7 drop all round. I dont know much about the specs but this was my results. just wanted to make sure i was within spec... the guy who drove my car staled twice and rode the sh*t out of my clutch.... smh
but heres the pic
Old Jul 19, 2011 | 01:35 AM
CleanFMtC's Avatar
looks like everything is back in spec besides the rear camber, which is close to spec... i have no idea what the red dashes are at the top of the pic though.
Old Jul 19, 2011 | 03:59 AM
Xx AzN xX's Avatar
ok thanks for the info, will that slight diffrence in the rear camber do any harm to my wheels?
Old Jul 19, 2011 | 04:45 AM
CleanFMtC's Avatar
It'll just wear the tires a little more on the insides, shouldn't be too bad since your toe is in spec and that's what kills tires most. I run -5.8 degrees on my Miata so you should be fine with that amount of camber.
Old Jul 19, 2011 | 05:26 AM
Xx AzN xX's Avatar
ok thanks man
Old Jul 19, 2011 | 06:12 AM
Spicy_McHaggiz's Avatar
Toe doesn't kill tires, camber does. But you'll be fine for wear. Being a point of a degree or two off from spec won't kill you, just make sure to rotate your tires. Also the fact that all the other measurements are green shows that you are within spec. Each alignment is car specific, meaning they load your vehicle into the computer then go off specs from their measurements. And if you really feel worried about it, buy a rear camber kit for 20 bucks.
Old Jul 19, 2011 | 07:30 AM
dropzone's Avatar
It'd been nice to see the specs before the corrections to know what he fixed or didn't attempt to. The red dashes I guess would be for caster, which has no adjustment on our cars. Only thing out of spec is the rear camber all else is in tolerance. The closer to 0 the toe is the better you are with wear, yes negative camber does add to wear, but toe intensifies it. Make sure to rotate the tires every 5,000 miles as mentioned in the owner's manual and you shouldn't have an problems.
Old Jul 19, 2011 | 08:26 AM
Camber wear
Toe wear
For better visuals.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Subaru86
Sep 14, 2015 12:51 PM
scionhawaii
Sep 1, 2015 08:14 PM
