Injen SES no resonator??
Old Jul 20, 2011 | 01:44 AM
ShawsSciontC's Avatar
Default Injen SES no resonator??
Im getting a Injen SES exhaust installed soon and i need to find out if i should take out the resonator and have it be a cat back or just leave it as a axel-back exhaust. Please help and thank you
tC Lover
Old Jul 20, 2011 | 02:02 AM
Jon's Avatar
Jon
Moderator
Moderator
If you're ordering the whole system, midpipe and axel back, then it's called a catback. If you're ordering just the muffler portion, then it's just an axel back. Removing the resonator, which is part of the midpipe, is just going to make it loud and will require some fab work. Not sure why you'd want to do that. If you want to know what it sounds like, you need to search. Youtube is a good place to start.
Old Jul 20, 2011 | 02:04 AM
See i keep looking but all i keep seeing is axel back which is wat im oredering im trying to see if its gonna sound bad if i remove the resonator or not? should i just leave it on?
Old Jul 20, 2011 | 02:08 AM
Jon's Avatar
Jon
Moderator
Moderator
Well if you're going to do that you may as well delete the catalytic converter too. Easiest way is to have a shop make you a midpipe and make it 2.5" while you're at it. It's just going to make it louder and possibly a little more raspy.
Old Jul 20, 2011 | 02:13 AM
Live in So Cal lol so yea any other ideas? I appreciate the help
Old Jul 20, 2011 | 02:21 AM
Jon's Avatar
Jon
Moderator
Moderator
Well the car has 2 cats on it, so deleting the secondary won't throw a code. The O2 sensor is located on the header, so as long as you leave the primary cat on there you should be ok. You should also see if the Injen is CARB certified, because if it's not then I think they can get you for that from what I've heard.
Old Jul 23, 2011 | 03:23 AM
Erager09's Avatar
I have the ses axle back. Everything else is stock. I love the sound and ppl have said it sounds nice and low. Isn't annoyingly loud but enough...
Old Jul 24, 2011 | 12:00 AM
ESEMRFOZZ13's Avatar
rattttlllllleeeeed like a mother, took it off and cut it open to see how it was built. they overlap the inside and not weld so it ratlled bad.
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
prescottn
Sep 13, 2015 09:04 PM
Chrono
Aug 25, 2015 05:59 PM
