Pre-tune checklist
Old Aug 3, 2011 | 01:41 AM
blown_xa's Avatar
Default Pre-tune checklist
maybe a mod should sticky this...........
The purpose of this list is to ensure your car is ready for a tune, and to save yourself headaches and $$$ by avoiding issues during a tune.
Spark plugs: make sure they are new, correct heat range, and are gapped properly.. .028 is fine for low boost. .026 for 12 to 14psi . Built motor between .024 and .020 depending on boost target.
Exhaust: make sure there are no leaks, because the dyno probe will read inaccurately. If the leak is before your primary O2 sensor a good tune becomes impossible.
Check Engine codes: If you had check engine codes before you put a turbo on, they are not going anywhere. If the MAF or primary O2 sensor is bad... replace it before tuning.
Charge pipes: make sure they are bead rolled for anything above 10psi. Make sure all couplers are secure and in good condition .
Tires: Don't show up for a tune with corded tires, things will end badly .
Vacumme lines: Boost controller pressure source should be from compressor housing or charge pipe, not teed off a BOV. Make sure your engine management map sensor line is secure, if it blows off.... engine go boom.
Leaks: If you have JB Weld holding your radiator together, we aren't going to allow you on our $135,000 dyno.
Wastegate: If you are shooting for a 8psi tune, don't have a 14psi spring. On the flip, if you want 30psi, don't have a 5psi wastegate spring . Make sure wastegate dump won't melt or burn anything. If dump is under hood along with the air filter, a SERIOUS horsepower loss will occur. Motors don't like to consume exhaust gasses.
Gas: Don't show up for a tune with the gas light on, the tuner does need to hit the gas pedal. Full tank is prefered, unless the same shop tuning is doing a fuel pump install then 1/2 tank is fine. 91 to 93 octane!!!!!!!!!!!!!!!!!!!!!!!! May seem like common sense, but we drain a lot of gas because people show up with 87 octane, and we wonder why so much timing had to be pulled.
If I think of anything else, I will add to the list. If anyone else has something Ill add it.
Old Aug 3, 2011 | 02:08 AM
bdis3's Avatar
Oil change within last 1000 miles, Proper fuel for different maps, fluid levels, and make sure the car is safe for the tuner to drive for a road test, example, make sure our seatbelts/harnesses work.
Always bring some spare cash. You might have missed something, and fixing stuff on the dyno is pricey, some shops charge dyno time to work on your car on the dyno.
Old Aug 3, 2011 | 11:27 AM
rhythmnsmoke's Avatar
Music City Scions
Good thread, no one has put a Pre-Dyno thread together before.
Old Aug 3, 2011 | 01:25 PM
paul_dezod's Avatar
Scionetics
KAD
I agree 100% here.
Full fluid top off, full safety from tires, brake lines, seats etc.
No bent wheels, toasted wheel bearings etc.
Make sure setup is flawlessly installed with no leaks on anything: exhaust, vac lines, oil etc.
Old Aug 3, 2011 | 04:24 PM
trd07tc's Avatar
lol everyone is doing these now. Probably about 20% of cars that are tuned have no problems. Im also feeling generous with that number.
Old Aug 3, 2011 | 05:08 PM
skinnayyy's Avatar
Team Scionara
also, with the fuel part, i would recommend not getting filled up at a cheaper gas station that you've never heard of or when they are adding gas to the tanks at the gas station.
Old Aug 3, 2011 | 05:15 PM
bdis3's Avatar
Unless you go out of the way to go to that gas station every time, I usually tell people to have gas in there car from where they will be getting gas most of the time.
Old Aug 3, 2011 | 06:50 PM
Syldrin's Avatar
i don't even work at a shop and i've seen this before.
i'd say things to prepare for should be added
Dont show up on a stock clutch and chew out the shop because it started slipping.
Old Aug 3, 2011 | 10:47 PM
crush02342002's Avatar
all of this should be common sense but I know what its like....Iv wasted quit of bit of time having to fix things before i can tune a customer. Iv gotten soo used to it I check everything out before i ever hook up my laptop.
Best thing I can tell folks is to call their tuner and ask what they recommend should be done before showing up for a tuning session.
ill see about making this a sticky....
Old Aug 4, 2011 | 06:32 AM
ScionFred's Avatar
Minor question here but is it really necessary to run a .028 plug gap for low boost? TRD recommends .032 for the SC and that's what I'm running with a T3/T04E at 6 psi. No misfires since I replaced the ND coppers with NGK iridiums. The coppers had trouble firing at 11:1 AFR but the iridiums don't.
Old Aug 4, 2011 | 08:46 PM
Syldrin's Avatar
i was getting blow out at .32 on 8.5 psi
Old Aug 4, 2011 | 09:51 PM
ScionFred's Avatar
Thanks, I suppose I'll re-gap them to .028 next time I have a chance.
Old Aug 5, 2011 | 02:09 AM
trd07tc's Avatar
Needs fuel/timing adjustments. I have no ign problems at 25PSI with .030 gap
Old Aug 6, 2011 | 05:47 AM
DeAnzaJig's Avatar
bring plugs with you, in case they dont carry the ones you have
Old Aug 8, 2011 | 03:26 PM
skinnayyy's Avatar
Team Scionara
and because don't they foul out sometimes during tuning?
Old Aug 9, 2011 | 05:39 AM
DeAnzaJig's Avatar
yea, thats happened to me before and they didnt have the plugs i needed, and the only other race shop by me didnt have them either.....it sucked! lol
Old Aug 9, 2011 | 03:03 PM
Slikk's Avatar
Music City Scions
wish i had seen this earlier... sorry about the 87 Octane
Boost No0b error.
Old Aug 10, 2011 | 09:22 PM
PeArLwHiTe07tC's Avatar
this one should be mandatory in ur list....dont bring friends that are bad influences either. my buddy talked me into havin em change the fuel pump. i went in lookin to spend around 500, walked out spending 865 w the tune, plugs, and pump w install. if u dont have all of ur mods in check, dont walk in the any less than a g in ur pocket.
altho, im very happy and pleased w my outcome, my bank account doesnt seem to feel the same as i do.
Old Aug 10, 2011 | 10:53 PM
blown_xa's Avatar
Boost No0b error.
What is ironic about that situation, is that you had your car prepped nicely ready for boost!
Old Aug 11, 2011 | 02:57 PM
Slikk's Avatar
Music City Scions
I was working on my checklist for months before I showed up... and still failed. ha ha
I am have a few more tweaks in to add them i will be back up there for a boost upgrade and tune.
