aem fic will not connect
Old Aug 7, 2011 | 04:43 PM
troy2003's Avatar
Default aem fic will not connect
ok, well i bought the fic used so i have no disc, i downloaded all the programs off of AEMs forums. Im not so sure i downloaded what i needed to, but my question is when i plug the fic to the usb and open up AEM Pro v1.0 it says "failure connecting to ecu", AEM injection monitor also displayes "disconnected. I just want a way to view and track real time boost, af/r, ect...ect...and log the data also, if thats an option. I am going to simply remove all the programs, and maybe someone on here can walk me through what the "only" programs i will need to download are, how to communicate with the fic(ecu), and what options these programs offer to me....
p.s., ive searched not only scionlife, but google searched as well, and couldnt find an answer in laymans terms to simply tell what programs are needed and how to communicate.
Old Aug 7, 2011 | 09:34 PM
troy2003's Avatar
Jesus...i just read over my post, looked like i was drunk or speaking broken english, lol, anyways it was 830 am, maybe that was why. Well ill bump this up to see if anyone with the knowledge can chime in.
Old Aug 7, 2011 | 11:36 PM
OuterHeaven's Avatar
You may need to flash your AEM FIC firmware to the correct firmware for the version of the software you are using. I suggest getting the latest version and starting from there.
Old Aug 8, 2011 | 05:20 AM
ScionFred's Avatar
Start here:
http://www.aemelectronics.com/articles.php?tPath=3_5_4
The FIC software you need first is here:
http://forum.aempower.com/forum/inde...c,22476.0.html
With this you can re-flash the FIC, tune, monitor and data log. You can then import data logs into AEM Pro. There's a lot more info at the AEM forums and their website has DIY vids that walk you through everything. GL
Old Aug 8, 2011 | 09:40 AM
crush02342002's Avatar
^^what he said
Old Aug 8, 2011 | 11:57 AM
troy2003's Avatar
Originally Posted by ScionFred
Start here:
cool, 1 question though, correct me if im wrong but i dont want to reflash the fic without having my tune on file correct?? im still trying to get it from my tuner if hes still got it.
Old Aug 8, 2011 | 11:13 PM
the tune is on the fic...you can get your tune off of your fic and onto your laptop/desktop. what you do is open up a map on your pc (base map or a cal someone has sent you) then click connect to fic, a box will pop up saying that the cal on the pc does not match the cal thats on the fic, there will be two buttons on the right saying "to fic" and "from fic". click on from fic, this will overwrite the cal you opened on your pc with the cal thats on the fic.
however your tuner could have put a pin number on the cal, if so you will need to get that pin number from him before you can open up that cal.
brett561tc
Sep 15, 2015 06:33 AM
Nkelly
Sep 7, 2015 05:06 PM
Armystrong
Aug 31, 2015 08:19 PM
iFangy
Scion tC 2G ICE & Interior
Aug 20, 2015 06:16 PM
Azsundevil
Jul 25, 2015 11:10 PM
