25k tune up
Old Aug 8, 2011 | 08:35 PM
KenRC51's Avatar
Default 25k tune up
I'm about to bring my car in for tune up for 25k. I don't like bringing it in a toyota dealer because its expensive. I usually buy the parts and just have a loacl shop install them for me. So far, I have only been doing oil change like that. I would buy the filter and systhetic oil and they would charge me $9 for the change and disposal fee.
So for a 25k tune up what should I buy? I hear some squeaking on brakes so i think I need brakes. I for sure need oil filter and oil, how about air filter or cabin filter? Should I change transmission oil?
Old Aug 8, 2011 | 09:19 PM
SamCarroll's Avatar
Oil change, engine/cabin filter, check other fluids, check/replace brakes, check belts. Good to go.
Old Aug 8, 2011 | 09:20 PM
divisii's Avatar
IMO tire rotation, a K&N drop-in air filter, synthetic/high temperature performance trans oil; look at the brakes and see that they're within spec (street-use should be good for at least +40k tho)
Old Aug 8, 2011 | 10:16 PM
Vlad1024's Avatar
Go with what the maintenance guide says. If it's an auto I suggest changing the fluid every 30k. Manual every 50k. also look for the diy cabin filter thread, it's really simple and cheap.
Old Aug 9, 2011 | 01:55 AM
Roller_Toaster's Avatar
Ditto, I have enough material to make at least 10 more, and it only cost me around $10 from lowes.
Old Aug 9, 2011 | 02:54 AM
SamCarroll's Avatar
i bought the premium cabin filter. The previous owner was a smoker and the charcoal cabin filter helps a lot.
Old Aug 10, 2011 | 03:09 AM
KenRC51's Avatar
What type of cabin filter should I get?
Should I replace my oem air filter with an K&N filter?
I think I might need to change my brakes, what type of pads should I buy?
I want something that will be better than my oem, but oem are fine.
Old Aug 10, 2011 | 03:22 AM
Vlad1024's Avatar
Just get a home furnace filter from Lowes, cut it up, and put it in yourself. Cheap and effective.
The oem filter is fine(and cheap) and lasts 30k.
This has been widely discussed here so do a search. I went with oem pads. My friends go to napa and get the second cheapest pad and they work well on a daily driver. Also, you shouldn't need new ones at 25k, the lube on the back of the pads probably dried up causing the squeek.
I want something that will be. better than my oem, but oem are fine.
Why? grippyer(I know, not a word...) pads will produce more dust, heat, and eat up your rotors quicker. You would not see any real gains unless you autox or do some sort of racing.
Once again, with few exceptions you should just go by what the maintenance guide says. Yaris owners routinely get over 300k with no issues doing that.
Old Aug 10, 2011 | 04:55 AM
KenRC51's Avatar
Alrite then, OEM all the way!!!
jthistle
Oct 5, 2015 09:32 PM
goldtoaster
Sep 25, 2015 04:58 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
Gigs
Sep 15, 2015 03:54 AM
