Swapped the Flasher and traction switches and moved the BT switch
Well, loving the xB for the most part. Coming from a tC and losing the automatic up/down for windows is lame as well as having to turn the lights on/off everytime. Getting used to that, I hated a few other things.. things though that I could change.
That being said, I never use my hazzards, so that spot could be opened up. The Bluetooth switch is stupid retarded where its at. So I put the BT in the black spot by the shifter and swapped the traction and hazzards switch locations by extending the wires. Love this so much more.
Also, added another cig lighter. One does not do much for a family. Simple deal, had it apart as I was running wires for underseat lighting so I said what the hey, do it while its all a mess.
Looks inventive
! Though I'm a little confused, my 2008 xB2 doesn't have even one cig lighter, so I've no idea what you're talking about with adding "another" cig lighter. There is an automatic "down" for the driver's window, but I'm not aware of an "up". I only use my hazard flasher when the car is disabled (like out of gas) -- but naturally, if that situation doesn't occur, you'll never have the need. I guess all that matters is you can readily find it should circumstances dictate
I'm guessing the last three photos are associated with the shift console front panel and the addition of a 12V port -- cig lighter? Still, I gather you're accustoming yourself to the xB2 and that's great. No doubt it's quite a different driving experience from your earlier tC. Hope everything works out well
!I'm guessing the last three photos are associated with the shift console front panel and the addition of a 12V port -- cig lighter? Still, I gather you're accustoming yourself to the xB2 and that's great. No doubt it's quite a different driving experience from your earlier tC. Hope everything works out well
Looks inventive
!Thread
mc1114
Scion tC 1G Aero & Exterior
Apr 23, 2020 10:34 PM
Boomshaker
Jun 28, 2015 02:37 AM
dchan8
34
Mar 26, 2004 04:37 AM
bbdude
Jan 15, 2004 02:42 AM
