Scion tC 2G ICE & Interior In-car entertainment and electronics...
help with led guage swap
Old Sep 1, 2011 | 04:22 AM
DtrTc2's Avatar
Question help with led guage swap
hey guys im convertin my guages over to led but i cant figure out how to seperate the lil plastic piece in the needles to remove the orange and im afraid i might brake em, so if anyone knows how to seperate them plz lemme no its the only thing thats stopping me...
Old Sep 1, 2011 | 01:31 PM
XPRTc's Avatar
If it's anything like the tC1 swap then you have to cut the little plastic piece to dis-assemble and then super glue it back together when you'r finished stripping the orange.
Old Sep 1, 2011 | 02:27 PM
MightyP's Avatar
^ He's right.
I did it a little different, but it's not hard. When you pull the needles off and look at the underside, you'll see 2 plastic nubs. Those are what are holding the needle together. I just used tweezers to squish the nubs until the back popped off. I swapped the color and popped the back on again. I didn't use any glue and the needle stays together just fine.
Old Sep 1, 2011 | 06:20 PM
DtrTc2's Avatar
Cool thanks for the help
Old Sep 1, 2011 | 06:40 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
don't mean to thread jack, but since u got ur answer...maybe we can repurpose this thread so i dont have to make a new one...
does anyone have a photo of all the lights on the gauge? i want to get an idea of what colors i would want to change on the indicators lights
Old Sep 1, 2011 | 06:42 PM
DtrTc2's Avatar
Ill post some when im done I did my guages white ut where my rps redline I did the led red and my indicators blue and thw needles blue
Old Sep 3, 2011 | 03:21 AM
BeloZero's Avatar
Look at my thread GAUGES!!!!. There are a few different pics in there of led swaps done on the tc2.
Old Sep 3, 2011 | 03:23 AM
DtrTc2's Avatar
Ok so everythins done and for some reason the only led that works is my high beam... Any ideas where I migjta gone wrong?
Old Sep 3, 2011 | 06:00 AM
MightyP's Avatar
LEDs installed backward, bad solder joint...
Old Sep 3, 2011 | 06:03 AM
DtrTc2's Avatar
The solders are good for the most part but backwards? Im a retard when it comes to electrical, im was under the impression there was no right or wrong way to put em
Old Sep 3, 2011 | 06:29 AM
BeloZero's Avatar
There should be a small notch in the corner of the led, put them on the same way they came off.
Old Sep 3, 2011 | 06:30 AM
DtrTc2's Avatar
Ok thaats what I thought but someone said they should all face down even though stock was up
Old Sep 3, 2011 | 08:05 AM
BeloZero's Avatar
no, thats a polarity mark. a LED is a diode so it only allows flow of current one way. i think they were all in the upper right hand corner when i did mine, i took a lot of pictures so if you cant figure out the polarity, i can send those to you.
Old Sep 3, 2011 | 08:07 AM
DtrTc2's Avatar
Ok that makes more sence thatnks for ur help
Old Sep 3, 2011 | 04:11 PM
MightyP's Avatar
Bloodborn did a very good write up on this.
https://www.scionlife.com/forums/sho...d.php?t=200646
Old Nov 8, 2011 | 09:58 PM
Ultimaniac's Avatar
I just pulled out my gauge cluster and have it mostly disassembled, but I'm having a problem trying to get the needles/***** off. Bloodborn's write up says to pull up but when I do so they do not pop off. It's possibly that I'm not pulling hard enough but I'm fairly confident they should have come off with the amount of force I applied. I don't want to do any damage. Do they have to be in a certain position to come off? They are all zeroed and the cluster is flat. I'm pulling directly up but they are stuck on there pretty well.
It's a 2012 tc.
Thanks in advance.
Old Nov 8, 2011 | 10:01 PM
DtrTc2's Avatar
Pull hard as all hell I was scares to brake em to but just pull hard
Old Nov 8, 2011 | 10:23 PM
Ultimaniac's Avatar
thanks I'll give it a try
Old Nov 10, 2011 | 07:58 AM
SquallLHeart's Avatar
i have a pair of angled tweezers i like to use to pry those needles off..
but yeah... they come right off. just make sure and pull straight outwards.
Old Nov 10, 2011 | 12:03 PM
Ultimaniac's Avatar
I got them off and the soldering went smoothly, I now have blue gauge lights. Thanks for all the help. I do, however, want to change those orange strips on the needles to make them blue (or green or white). I couldn't figure out how to get them off though, has anyone done this?
