Lambo Doors... Rolled Fenders?
Old Mar 22, 2005 | 07:07 PM
superfreestyle's Avatar
DeepSouth Scions
Default Lambo Doors... Rolled Fenders?
I have seen the lambo door kit on ebay and it is advertised as bolt on, no cutting or welding required, but it says that the fenders must be rolled. What does this mean "Roll fenders". the only time that i have heard this term used is when you roll a fender so that the tire doesnt rub.
Old Mar 22, 2005 | 07:59 PM
DJ_X_Trodinaire's Avatar
where the kit mounts (door and fender)
you probably have to "roll" the edge of the fender so the kit would clear
Old Mar 22, 2005 | 09:50 PM
DeepSouth Scions
Well I understand that but I dont see why it would hit if the kit was made properly. It would look retarded to have a big gap there. Has anyone done this? Does anyone have pics?
Old Mar 22, 2005 | 09:57 PM
Sciond's Avatar
look at matchbox's pics
Old Mar 22, 2005 | 11:34 PM
ShredSled's Avatar
(This is Scion Life Member BIGShawnBlackXB's ride.)
Here ya go!
Old Mar 23, 2005 | 12:07 AM
dinkjs's Avatar
SCRISSOR doors are tacky unless done by the factory...waste of money.....I am gonna be different and stick with my stock hinges
Old Mar 23, 2005 | 12:16 AM
dgHotLava's Avatar
you do have to roll or trim the inner fender... no other way around it...
rolling just means bending out of the way...there is a lip under the fender that will hit the hinge and prevent the door from coming down all the way...it must be trimmed or bent (rolled)
Old Mar 23, 2005 | 12:56 AM
TheScionicMan's Avatar
You're not rolling the fender edge next to the door, but the inside area between the fender skin and the body. Like when you roll the fender, it doesn't make the fender opening larger, it flattens the material sticking out the back side.
Old Jul 27, 2005 | 08:44 PM
REDRUMXB's Avatar
yes rolling the fender mean you have to either cut or dremel the inner lip of the fender that faces the body of the car so that the door kit has room to move freely.
Old Jul 28, 2005 | 12:05 PM
TheIcon's Avatar
Here is a close up of the hinge. If you look at how the arm opens and raises and then you take a look at your door now, and look in the fender well you will see that the hinge won't fit bcause a long strip of metal is in the way. So this piece has to be cut away or rolled(bent in)
Original Hinge
Lamob Hinge
Old Jul 30, 2005 | 01:18 PM
matchbox's Avatar
Default fenders
I just cut mine. You can get the door out a little farther. But still keep out the plus size ladies.
Old Jul 30, 2005 | 01:36 PM
FrankenScion's Avatar
Just go for some gullwings and be completely different.
Old Jul 30, 2005 | 02:32 PM
Boxer_Rebellion's Avatar
It would be cool to have them hinge off the A-pillar, McLaren F1 style...
yupinmytC
22
Jul 27, 2024 07:08 PM
BlingSlade
Oct 19, 2016 12:39 AM
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
jeremydoc
Sep 16, 2015 11:31 PM
