Wheel Spacers
Old Sep 17, 2011 | 03:59 AM
QARDEL's Avatar
Default Wheel Spacers
Thinking about buying some wheels spacers after I drop a suspension kit in my tC2. Any recommendations? I'm planning on keeping the stock wheels for now. Thanks!
Old Sep 17, 2011 | 07:27 AM
Scion202's Avatar
15mm ichiba to flush the fronts and 25's to flush the rears
that is on dropped car...
Old Sep 17, 2011 | 02:24 PM
Brenex's Avatar
I think this was the link someone gave in another thread (might have been scion202) http://www.phantasmusa.com/ws5511460c.html
Old Sep 17, 2011 | 02:33 PM
QARDEL's Avatar
I'll look into that thanks!
Old Sep 17, 2011 | 07:20 PM
Scion202's Avatar
go to fastscions.com and select the spacers for XB2, it will show u the part number then just ebay with that!
Old Sep 18, 2011 | 03:43 AM
QARDEL's Avatar
Scion202 got a pretty sweet setup man. Thanks for the info too!
Old Sep 18, 2011 | 03:32 PM
2tCornot2tC's Avatar
Do not use any wheel spacers at all!
Old Sep 18, 2011 | 07:26 PM
Backinblacktc2's Avatar
@ 2tCornot2tC may I ask why? Please explain.
Old Sep 18, 2011 | 07:43 PM
rackatak's Avatar
Some people do not like wheel spacers because back in the day they were very dangerous to use. Alot of sheared studs or wheels separating from the vehicle. I have used wheel spacers before on a truck that I would take off road and had zero issues. They just need to be the proper type for your vehicle. I think the ones our cars use are hub centric. I will say use at your own risk and ensure they are properly installed and set to the proper torque specs.
Old Sep 18, 2011 | 08:22 PM
Scion202's Avatar
from engineering stand point its an absolute NO-NO
pros:
looks cool
wider stance
cons:
increased unsprung weight
increased complexity of a moving part
increased turning radius
increased force on the ball baring
Old Sep 19, 2011 | 03:41 AM
Discussed at length here…
https://www.scionlife.com/forums/sho...d.php?t=202891
Old Sep 19, 2011 | 06:40 AM
Scion202's Avatar
Where is my math/reasoning wrong?
7.5 inch wheel = 19.05 cm
center line = 9.525 cm
with offset of 39; 5.625 cm of wheel extend out from the hub and 13.424cm goes towards the car.
SO:
5.625/19.05 *100 = 29.528% of the wheel width extends out from the hub. So in order to keep all the forces equal, wouldn't you want that ratio to stay the same???
yours now:
9" = 22.86
center line: 11.43cm
with offset of 40; 7.43cm extends out from the hub
so 7.43/22.86 *100 = 32.502% extends out from the hub
Old Sep 19, 2011 | 11:48 AM
You are correct…but, the performance/handling of your vehicle and the loads that go through your suspension all go through the centerline (weather it is a tire, wheel or suspension component) therefore the “ET” is the most critical measurement on a wheel. The amount of wheel inside the mounting face is a reference for suspension and wheel well clearances and the amount of wheel outside of the mounting face is a reference for fender clearance. Yes, you have to check those clearances, but you design to the centerline. Unless you are capable of making some very major changes to the suspension design, do not change the “ET” of the wheel...a wheel spacer does that.
Check here https://www.scionlife.com/forums/sho...d.php?t=206561 to see what pivot radius is in the sketch of post #8...that, you wnat to keep at zero.
Last edited by 2tCornot2tC; Sep 19, 2011 at 12:59 PM. Reason: added suspension geometry
Old Sep 19, 2011 | 04:55 PM
Scion202's Avatar
so then which offset would hurt the suspension geometry and ball baring loading the most? going above 39 or below 39? or its the same?
Old Sep 19, 2011 | 05:29 PM
Hard to say without having the complete design…it’s like asking, would placing the crowbar on the inside be worse or using the crowbar on the outside be worse. You are still using a crowbar. Spacing the wheels (offset) is the crowbar…small (short), but your loads are large (weight of the car).
Old Sep 19, 2011 | 05:44 PM
WellesleyScion's Avatar
Old Sep 19, 2011 | 06:12 PM
Is that an aerial shot of the Arizona in Pearl Harbor?
Why did you post it here? Nice shot…but it doesn’t make sence…
Old Sep 19, 2011 | 06:13 PM
Brenex's Avatar
Is that what will happen if you install wheel spacers? I'm outta this thread then
Old Sep 19, 2011 | 06:16 PM
Thats what happens when you dont install spacers... sunken battleships...
Old Nov 14, 2012 | 03:32 PM
darwintheory's Avatar
dont mean to highjack this tread but i didnt want to start a whole other one just for this question lol ... i am on trd springs and trd 19 inch wheels and am going to buy spacers soon i will be getting 15 mm bolt on for the front and 22 mm for the rear .. will i have to shave down the oem studs ???!!!! or
