JL 12W7 amp
Old Sep 29, 2011 | 12:32 AM
djpax's Avatar
Default JL 12W7 amp
So I have been itching to upgrade my system and I decided to get a JL 12W7 in a sealed box. The guys at the audio shop told me to power it with a HD 1200/1. I was thinking of a HD750/1 but they recommended the bigger one.
I then told them that from my understanding the alternator in the tC will handle 1200 watts and I already have a 65x4 amp powering my full range speakers. That would put me at 1460 watts. They said I should be fine if I upgrade the battery.
So what do you guys think? Should I go with the 1200/1 and a battery? Maybe an Optima yellow top?
Oh, and another question. I was powering some subs before so I already have the wiring set up for the amp install, but now that I'm upgrading, should I use a bigger fuse on the power wire by the battery? I have a 150 amp fuse in there now. Is that good enough? Thanks.
Old Sep 29, 2011 | 01:57 AM
StreetSweeper's Avatar
Well what u are saying really don't mean anything. You need to find the total amp draw off both amps together to figure out fuse size. A minimum of 4 ga. Power n ground are needed. Yellow tops arnt recommended for main batteries they r used as a back up (IMO) I'd use a red top up front. The w7 is rated at 750rms so the 750/1 is enough for what u need
Old Sep 29, 2011 | 02:09 AM
Also why are you going with the w7? You could do 2 12 with less power with more bass. I have a w6 and I do mine for sound clarity but it sounds perfect for me.
Old Sep 29, 2011 | 03:27 AM
djpax's Avatar
OK, I told you the one amp is 65w x 4 and the second will be either 750 or 1200 so what size fuse do I need? And yes I have 4 gauge power and ground.
Old Sep 29, 2011 | 04:33 AM
What's the amperage draw off ur 4 channel
Old Sep 29, 2011 | 07:57 PM
djpax's Avatar
I don't know. It's a Elemental Designs Nine.4
Old Sep 29, 2011 | 09:31 PM
Man o man....ur 4 channel has a current draw of 60 amps the HD 750.1 also is about 60 amps so a 120 amp fuse is enough(fyi ur lights will hate u ) if u decide to run both off the 4ga. I would run a 0ga to a distribution block and take 2 4ga to each amp with a 4gs ground for each. U can also run 2 4ga back one for one and the other to another and fuse them at 60 each
Old Sep 29, 2011 | 11:10 PM
djpax's Avatar
Man, that's not what I wanted to hear. I was hoping I could get away with the 4 gauge that I already have and this would be an easy amp and sub swap.
Old Sep 29, 2011 | 11:20 PM
LOL yea man I know but that's the price u pay for a woffer of that status.
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
DannyBoy65
Sep 21, 2015 06:23 PM
crimson10tC
Sep 10, 2015 08:44 PM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
