I have a spark plug question
Old Nov 14, 2011 | 11:00 PM
scion86's Avatar
Default I have a spark plug question
Had a questions are these spark plugs good for a 06 TC with trd s/c
http://www.customcarscentral.com/ngk...-scion-tc.html
Spicy. Thanks
Old Nov 15, 2011 | 12:08 AM
rand0mher0's Avatar
Yeah those are the ones that come with the car stock I believe, those will do fine.
Old Nov 15, 2011 | 12:23 AM
Spicy_McHaggiz's Avatar
Some tC's came with Denso Iridiums, some came with NGK's. Either way, the spark plug is a 100K mile wear item regardless. Having an s/c on the vehicle makes no difference. Whatever you do, keep with Iridium plugs.
Also, instead of making a useless thread title, if you put some thought into it you'll get better and faster results.
Old Nov 15, 2011 | 02:21 AM
scion86's Avatar
Yea I no I'm sorry
but thanks for answering. I googled but got all sorts of different answers I just wanted one lol but thanks guys.
Old Nov 15, 2011 | 03:10 AM
kent55's Avatar
NGK Laser Iridium Long Life Part # 4589
http://www.ngk.com/results_app.asp?AAIA=1432816
Old Nov 15, 2011 | 04:46 PM
KiKaZ-tC's Avatar
The spark plugs required for the s/c Scion tc are
Ngk Bkr7e or Denso k22pru. Gapped to .032
These are both COPPER plugs and rated for around 30k miles.
There's a reason why TRD chose copper plugs over iridium, if you do your research copper plugs can take more heat then iridium or platinum plugs.
I just purchase NGK BKR7E and change them often since they're so cheap and readily available at auto parts stores (napa).
Old Nov 15, 2011 | 05:26 PM
rand0mher0's Avatar
Yeah same. Just did the spark plugs in the tC at like 76k, and replaced with these:
http://shop.advanceautoparts.com/web...RPTUNEAMS_____
Not iridium, but they still work, just dont last as long.
Old Nov 15, 2011 | 10:03 PM
scion86's Avatar
Im close to 80k. And I'm installing the trd supercharger.
So kikaz-tc the ngk plugs that you said ngk BKR7E
Are those the same as the link I put its for ngk BKR7EIX-11 it says 1 step colder. I read some where that 1 step colder was good I don't know what thats all about. I'm all confused lol. And I don't know about gaping eaither.
Old Nov 16, 2011 | 09:28 PM
KiKaZ-tC's Avatar
The standard NGK BKR7E is a copper plug which is perfectly fine to use for up to 30k.
The link your talking about for the NGK BKR7EIX is just the iridium plug.
Both are 1 step colder plugs and both would work fine.
I've never purchased the BKR7EIX iridium plugs, I use the standard copper plugs BKR7E and they've always come pre-gapped at .032 but you should definitely check the gap on each plug before installing.
http://ngk.com/results_cross.asp?pid=4644&x=0&y=0
Uploaded with ImageShack.us
Old Nov 16, 2011 | 09:30 PM
KiKaZ-tC's Avatar
These are both wrong, do not use either of these plugs if you have the supercharger kit. They are not 1 step colder plugs. I believe these would be for a stock scion tc.
Old Nov 17, 2011 | 12:10 AM
scion86's Avatar
Thanks kik
Old Nov 19, 2011 | 02:05 AM
Ab501u71yR3d's Avatar
They will only work for a stock TC yep...
Old Nov 21, 2011 | 05:06 PM
KiKaZ-tC's Avatar
Red face
Only use NGK BKR7E or BKR7EIX & Denso K22PR-U, unknown part# for Denso iridiums.
DO NOT use BKR7E-11 or BKR7EIX-11, these are both wrong as well.
Old Nov 21, 2011 | 05:30 PM
scion86's Avatar
Ok thanks the ngk do i gap it at 0.32. I was just goin to stick with denso but I heard really good things about ngk. So I wanna stick with them.
Old Nov 21, 2011 | 06:22 PM
KiKaZ-tC's Avatar
Yes, you will need to check the gap on whatever spark plug you choose to get.
I know the copper NGK BKR7E & Denso K22PR-U come pre-gapped at .032"
Old Nov 21, 2011 | 07:15 PM
scion86's Avatar
Sweet. Thanks.
my06tc
Jun 25, 2015 12:18 AM
daniinpitt
Apr 4, 2015 08:07 PM
Miqmiqmiq
Feb 4, 2015 05:05 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
