Amp Wiring?
I need help. Currently have 2- S10 l5 Solo Barics and a 1500 watt bx monoblock Hifonics Amp.
How do i wired it to be at 1 ohm or 2 ohms?
___
___
ok.....if you have dual 2 ohm voice coils....wire it like this.....this will give you a 2 ohm load....
if you have dual 4ohm subs, wire it like this.....this will give you a 1 ohm load....
and if your subs are single coil, wire them like this....this will give you a one ohm load if you have 2 ohm subs.......or it will give you a 2 ohm load if you have 4 ohm subs....
BTW.....if you don't know whether they're single or dual, look at the terminals on the sub itself.....if you have one positive and one negative per sub, you have single VC.
If there are 2 positives and 2 negatives, you have dual voice coil....on the back of the magnet there should also be a sticker stating the resistance(ohm) and # of voice coils.
Hope this helps.
__________________
Hope this helps.
__________________
Ty_Max
Scion tC 1G ICE & Interior
37
Apr 3, 2007 05:30 AM
Prototype_xB
20
Jan 3, 2006 01:55 AM
bdonscion
Apr 15, 2005 11:24 PM
