Project Kics wheel adapters
Hey guys, so im trying to change my bolt pattern to 5x114.3. I want to get the project kics wheel adapters in 10mm or 15mm but I cant seem to find a place that sells them so please help. And im thinking that these are pretty much the same ideas as spacers but changes your bolt pattern so im guessing that the stock studs will poke out right? Thanks for the help
google search it, not that hard
example:
http://www.google.com/m/products?cli...wheel+adapters
M12x1.5 is the thread pitch you'll need. Also yes, the OEM wheel studs will still stick out. To clear them I recall it'll take 25MM thick adapter, IDK about a 20MM, take a wheel off and break out the measuring tape.
example:
You need to do a lot more reading. Your wheel choice will determine whether or not you'll be able to use the 15mm adapters. The stock studs will stick out and if the wheel doesn't allow for it, you will have to cut them.
CombatmedicR56
Nov 12, 2020 01:53 AM
reagan9000
Jan 28, 2015 06:20 PM
