TRD Flash Question
Old Dec 14, 2011 | 11:58 PM
warr40's Avatar
Default TRD Flash Question
Looking to install my supercharger soon once i find out what the deal is with my oil consumption.
Is is possible to drive the car stock with ECU flashed.
Or is it possible to install the supercharger and drive it to the dealer with the un-flashed ECU?
Would like to avoid paying for a tow.
Old Dec 15, 2011 | 01:02 AM
scion86's Avatar
I haven't installed mine yet. But I asked that question be4 and no you can't drive it u got to tow it. Or get a ecu that's already flashed. Thats what I did.
Old Dec 15, 2011 | 01:38 AM
warr40's Avatar
I thought the ecu had to be flashed in the car. If not i could jus bring the ecu to the dealer?
Old Dec 15, 2011 | 01:48 AM
tCb00b's Avatar
Contact TRD Sparks in Myrtle Beach. I remember they offered a mail-in reflash for the TRD kits. Not sure if they are still doing it or not.
scion86's Avatar
Yea it does have to be flashed in the car with the supercharger already in but u will have to tow it. some ppl sell the ecu already flashed and all u got to do is just install same day as u install the s/c its alot easier and cheaper.
Old Dec 15, 2011 | 01:50 AM
warr40's Avatar
Sound like ill be on the look out for an flashed ecu.
Old Dec 15, 2011 | 02:00 AM
scion86's Avatar
Yea check the for sale or eBay make sure its flashed.
Old Dec 15, 2011 | 04:10 AM
ScionCREW's Avatar
i drove my Xb to the dealer with the supercharger. just dont go in to boost..
Old Dec 15, 2011 | 04:13 AM
warr40's Avatar
hmm what if i put on a dummy intake and leave the SC charge pipe disconnected?
Dumb idea?
Old Dec 15, 2011 | 07:07 AM
DeAnzaJig's Avatar
Dumb idea?
I did that once when i was turbo. But make sure you let the car re-learn to make proper fuel trims prior to driving it. Only will work with 440cc injectors or smaller. 550s will be too much of a trim and the stock ecu will not be able to keep up.
Drive really conservatively. You wont mess anything, if everything is installed properly. The worse that could happen is you will run rich. Otherwise id say its ok. Ive done way riskier things
Old Dec 15, 2011 | 07:09 AM
DeAnzaJig's Avatar
Dont take my word for it though. I wouldnt recomend anything like that, i wouldnt recomend anything but doing it perfect. But to answer your question, yes, it can be done.
Old Dec 15, 2011 | 01:58 PM
sci0n-tc's Avatar
Installed my s/c a wile ago, I ran my stock ECU for 2 weeks and the car ran fine staying out of boost of course. Pretty sure the ECU would go into limp mode if it started reading pressure. I would suggest buying a re-flashed ECU here in the classified section and re link the transponder with the ECU as shown in link (https://www.scionlife.com/forums/sho...d.php?t=208369)
Hope this helps
Old Dec 15, 2011 | 04:08 PM
draxcaliber's Avatar
no, you can blow the motor with the supercharger and stock ECU. It has been accomplished by somebody on this forum.
cost benefit analysis: savings of driving the car yourself VS paying for a reasonable tow VS paying for a reasonable tow and rebuilding or replacing engine...seems like a no brainer to me.
Old Dec 16, 2011 | 12:22 AM
ESEMRFOZZ13's Avatar
the tacomas used to just bolt on a charger with no ecu tune. "scioncrew" how can he avoid not boosting, on a belt driven charger?
Old Dec 16, 2011 | 02:20 AM
ScionCREW's Avatar
lol ok with some discipline and common sense im sure he can drive his car to a local dealer and get his ECU reflashed.
Old Dec 16, 2011 | 03:15 AM
i was just being a smart@s$ with the given opportunity.
Old Dec 16, 2011 | 03:21 AM
warr40's Avatar
to avoid any problem i think i'll just bite the bullet and get a tow.
If i cant find a flashed ECU
Old Dec 17, 2011 | 10:59 PM
thiers one in classified right now.
Old Dec 18, 2011 | 05:50 PM
DeAnzaJig's Avatar
definately get one from here or somewhere else. dont go to the dealer. when i first bought my tc, it came supercharged. long story short it ended up stock with a stock ecu, then decided to put it back on a few months later...lol i know. i got a quote from a dealership for the reflash for $400!!!
Old Dec 26, 2011 | 04:51 AM
tCZion's Avatar
You can install your supercharger and pull out the ecu, take it to the dealer, reflash it and the back to your car. that the way that I done this, there is no need to be in the car. And never run the stock ecu with the supercharger installed, you can damage your engine............
