Manual Trans shift boot on an automatic
Old Dec 20, 2011 | 03:51 AM
Evo6Z28's Avatar
Default Manual Trans shift boot on an automatic
Any idea how to pull this off? I know I have seen this on one members car but i don't remember who it was.
Old Dec 20, 2011 | 08:03 AM
drivenTC's Avatar
https://www.scionlife.com/forums/sho...ight=shiftboot
Old Dec 20, 2011 | 04:46 PM
Cody2005's Avatar
i did it. it was super easy. unscrew and remove the shift ****. pop off the plastic housing around the shifter(silver plastic with the p,d, etc.) then pull off the black plastic piece that sits flat on the same area (it has the 2 pieces on the sides that run into the waterfall). just turn the boot inside out and glue to the inside of the black plastic piece. hard to understand without pictures. sorry but you get the gist. its easy. good luck.
Old Dec 20, 2011 | 10:09 PM
karmajack's Avatar
Just found this place. You can buy boots here, and they show a how to swap. http://www.redlinegoods.com/ScionTc04install.php
Old Dec 20, 2011 | 11:43 PM
testa422's Avatar
i have done this with the oem manual shift boot...easiest mod ive done to the car so far! pull apart as stated above and snap in oem boot
Old Dec 21, 2011 | 01:04 AM
Cody2005's Avatar
this is where got my info for doing mine. i tried taping and using a coat hanger but neither would hold so i glued it.
Old Dec 29, 2011 | 03:29 AM
jazfromhouston's Avatar
Mine is an auto too.. One of the first to do this.. Just watch out as valet drivers get confused quite easily.
Old Mar 12, 2012 | 08:13 AM
marcossolares's Avatar
I tought u just had to screw it off
eric_m
52
Jan 17, 2019 05:50 AM
tckid21
Mar 12, 2017 09:16 PM
AMLorick
Jan 25, 2015 12:14 PM
mischman
Jan 14, 2015 06:07 PM
bbdude
15
May 8, 2004 05:14 AM
