Question about Transmission fluid&power steering fluids.
Old Dec 28, 2011 | 11:25 PM
Kai99's Avatar
Default Question about Transmission fluid&power steering fluids.
Hi all
I just got done my 36k services at a shop, they did a full inspection, recommanded me to flush my transimission and powersteering fluids.
Is it necessary for 36k?
Thank you.
Old Dec 29, 2011 | 12:53 AM
thendawg's Avatar
On a 2009, the ATF is SUPPOSED to be a lifetime fluid. No need to service it unless you have an issue with the trans. As for power steering, I believe its recommended every 36k, but I never changed mine until I built the motor and everything (I was around 70K). When I dropped the motor back in i flushed it and put all new fluid in it, however the old fluid looked fine. Up to you on that.
Old Dec 29, 2011 | 10:19 PM
tomb302's Avatar
Does this also apply to the 2006 Models as well?
Old Dec 29, 2011 | 10:26 PM
Jon's Avatar
Jon
Moderator
Moderator
Isn't the first a/t transmission flush recommended at 120k? I think that's what the maintenance book says.
Old Dec 29, 2011 | 11:35 PM
thendawg's Avatar
Heres the TSB on the WS fluid. TC's from 07-up used WS. 05-06 used the older T-IV ATF which followed a standard service interval. According to the TSB it should be inspected at 100k but never actually serviced/flushed. Funny enough, the trans itself didnt actually change. When I boosted my auto I drained the WS fluid, flushed it, and put in Royal Purple Max ATF which qualifies as a T-IV. It helped alot with the shifting under full throttle. WS is designed to be longer life and more efficient, but seems to not do to well in harsh conditions.
http://www.etimago.com/yaris/TSB/TS-...0Fluid%20).pdf
Old Dec 30, 2011 | 10:14 AM
Kai99's Avatar
Thanks guys.
Guess I will hold onto it for another 30k then........
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Beesh
Jan 9, 2015 06:30 PM
