lug nuts
Old Jan 9, 2012 | 06:25 PM
2011xb4me's Avatar
Default lug nuts
what kind of lug nuts/ what size do i need for my xxr 521's?
Old Jan 9, 2012 | 08:09 PM
09RSXB's Avatar
let me know as well
09RSXB's Avatar
what color u buy?
Old Jan 9, 2012 | 08:31 PM
itscurtsk's Avatar
You need TUNER lug nuts. Pitch should be 12mm x 1.5. I think all Scions are the same. Not sure.
Old Feb 2, 2012 | 05:38 AM
js2sta's Avatar
Im using these extended lugnuts from Zerg Industries. pretty sicc.. they have removable end caps, so you switch from close end lugnut to an open end.
http://www.streetlightz.com/product.php?pid=137
Old Feb 2, 2012 | 05:49 AM
xseveredveganx's Avatar
Utah Scions
Iiiiinteresting...
I've been looking for some lug nuts, preferably extended and black. However most are open ended, which I'm kind of iffy about because of salt on the roads and things like that.
Old Feb 2, 2012 | 07:49 AM
VENisME's Avatar
Those look good and aren't very expensive compared to say volk's set.
Old Feb 2, 2012 | 05:10 PM
dspeedy69's Avatar
so the Hex key im guessing is to convert them to open ended?
Old Feb 2, 2012 | 05:47 PM
ScionFred's Avatar
To all: Keep in mind that the oem wheel studs are short and may require extended shank lug nuts (ET) with certain aftermarket wheels. Whatever you do, DO NO try to install any size spacers without longer studs.
If you can get 8 full turns on each wheel nut, you have adequate thread engagement. Less than 8 turns and you should use ET style nuts. With my MSW wheels I only had 7 turns so for safety sake I'm running Gorilla ET nuts.
Old Feb 2, 2012 | 06:51 PM
Utah Scions
Good information here. I highly suggest the same about the spacers.
Anyone know of any reasonably priced extended studs, perchance? I'm considering Ichiba's, and ARP's are too expensive for what I need them for. I've read that the EVO lug studs will fit with Scions.
Old Feb 2, 2012 | 07:09 PM
vancouverray's Avatar
I used H&R . They don't have the a list for 2012 xb yet . However the Camry 2012 is the same .
Old Feb 2, 2012 | 11:20 PM
ScionFred's Avatar
According to Dorman our oem studs are; Thread; M12-1.5; Knurl Dia.: 14.20mm; Length: 40mm; Shoulder Length: 8mm (#610-266)
They also make 44.1mm long studs with a shoulder length of 17mm (610-462) that should work fine. Just make sure that the longer shoulder won't be a problem with steelies or the temp spare.
For use with spacers they have 610-463 which are 55mm long with a 26.6mm shoulder. Again the shoulder length could be an issue but if any of these work for you, they only cost about $1 each.
Old Feb 2, 2012 | 11:37 PM
Utah Scions
Where are you finding them for $1 each!? I found them on Summit and some other spots for about $2 apiece.
Actually I think the ones without the shoulder would be better...
Old Feb 3, 2012 | 02:12 AM
js2sta's Avatar
yes.. hex key is for removing end caps to make 'em open ended..
Old Feb 3, 2012 | 03:46 AM
ScionFred's Avatar
I didn't shop around much but Rock Auto charges $0.88 each for them and I saw them elsewhere for $10 for a 10 pack.
The 17mm shoulder would be fine for alloys with conical seat lugs but to use the 26.6mm shoulder studs would require a 10-15mm spacer. If using spacers, the longer shoulder studs would be stronger.
Old Feb 3, 2012 | 05:51 AM
Utah Scions
I may just pull the trigger on some Ichiba studs... found some other studs on eBay, but kind of iffy going that route.
Old Feb 3, 2012 | 02:27 PM
alfundo's Avatar
Lehigh Valley Scions
just ordered a set!
Old Feb 3, 2012 | 10:30 PM
xris217's Avatar
12mm x 1.5 from Autozone.. Chrome but painted it glossy gunmetal.
Old Feb 3, 2012 | 11:47 PM
Utah Scions
Pulled the trigger on the Dorman 55mm ones... we'll see how they work. Going to run 10mm spacers. Probably a little overkill, but I eventually want to run 15mm. Just going to 'borrow' my buddy's 10mms.
Old Feb 4, 2012 | 06:55 AM
ScionFred's Avatar
^^^ I hope they work out for you. Let us know how they do.
