2011-____ [ANT20]
SRI Vs. CAI
Old Jan 15, 2012 | 04:17 PM
yardleyTC's Avatar
Default SRI Vs. CAI
Ive been looking all over to see what the best overal package for the tc2 is relating to the intake systems. Im looking to see if most people run on SRI or CAI, if so where have you felt power gains and where have you felt a loss in power? i noticed recently that people have been saying more and more that they took off certains brands of intakes due to them being robbed of all of their power. Im a college student in Canada so funds are not massive, id prefer to get it right the first time!
Thanks for any input
Chris
Old Jan 15, 2012 | 04:20 PM
210of2200RS7's Avatar
injen cai. u can switch it to sri if needed
Old Jan 15, 2012 | 04:38 PM
yardleyTC's Avatar
thats what i was looking at. that does seem to be the best. Do you know how the power band is with both of them?
Old Jan 15, 2012 | 04:50 PM
biglilsteve's Avatar
SRI is near pointless when it comes to power. Sure you may get more airflow, but since its just the hot and non-dense air floating around the engine bay it defeats the purpose. Just adds noise.
Go with a CAI. And you don't need to worry about water. The area where the filter is located is well protected from water. I have had my takeda in for several months and have been through all kinds of heavy rainfall without any issues.
Old Jan 15, 2012 | 06:07 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
Descendant can do it too
Old Jan 15, 2012 | 06:09 PM
Emo1127's Avatar
Yeah I was looking at CAI as well didn't know who to go with for best performance.
Old Jan 15, 2012 | 06:42 PM
yardleyTC's Avatar
Exactly i was looking to seehow the power band was brand to brand.
Old Jan 15, 2012 | 06:45 PM
yardleyTC's Avatar
The issue in Ottawa is that there is tons of snow im maybe a little bit worried about getting it wet.
Old Jan 15, 2012 | 06:55 PM
Emo1127's Avatar
Well the my boy the black mamba is running with desendent and it seems to be a good price.
Old Jan 15, 2012 | 07:17 PM
ESEMRFOZZ13's Avatar
ok here we go,+) short ram was better throttle response in take off.+) short ram air cools off once driving, -) the a/f ratio goes awol at around 5k rpm. c.a.i. +) air is just about 2 degree difference from outside temp. +)not as loud, +)a/f ratio stays smooth, -) easy but pain to clean filter, -)the off the line response sucks at normal take off. just my thoughts, and not in stone.
Old Jan 15, 2012 | 07:32 PM
yardleyTC's Avatar
Ya I understand that. And they all makes sense. I'm looking for concrete brand testimonals. And what not to buy!
Old Jan 15, 2012 | 07:39 PM
devanb3's Avatar
heres what i have found out over the years...
CAI
-better HP and TQ
-Because its lower to the ground more dangerous in messing up your engine if you go through water
-less mpg then stock because its pulling more air= putting out more power...
-can set off the Check engine light due to the increase air or if any moisture gets in
RAI
-better TQ and HP then stock but not as good as CAI
-better for areas with alot of rain and Humidity
-sits on top of a engine so it is still getting warmer air which means you get better mpg then a CAI but still get the cleaner air then the stock
EDIT: I have a Takeda CAI that i love for the power gains however i mainly drive in the city and it dropped my mpg down about 3-4 mpg and im not sure that its worth it right now since i dont use the power that often
Old Jan 15, 2012 | 07:53 PM
engifineer's Avatar
A typical living environment in the upper midwest can see temp swings of 120 degrees across a year. Even driving down a road and passing over a shady or damp section of pavement can cause large instantaneous temp swings. A 2 or 3 degree change in iat due to a cai and the associated air density change is not going to throw afr's off (your maf and ecu are set up just for this function, hence the name mass air flow sensor).
These intakes do almost nothing overall for performance. Noticable change on the 1st gen tc (other than those whose butt dynos are fooled by loud noises) and likely just as little on the 2nd gen. Newer cars have pretty decent intake designs from the factory.
And yes, an sri is drawing hot engine bay air. A metal tube cai also heat soaks like crazy every time you stop. So there are downfalls there as well.
They make the car sound kind of cool, dress up the engine bay and maybe add a tiny little performance gain, so buy mostly based upon build quality and price. Or build the gfi (search for it) which is cheaper and heat soaks less.
I ran a 1st gen without a cai, then with one for a long while, then without. Honestly no noticeable difference other than very slight fuel economy improvement when going back to stock.
Old Jan 15, 2012 | 10:42 PM
Scion202's Avatar
all the info dumping/sharing should be in here for better organization
https://www.scionlife.com/forums/sho...d.php?t=203274
Old Jan 15, 2012 | 11:24 PM
yardleyTC's Avatar
I was looking for not numbers per say but more personal views after use.and why people changed from one to another
Old Jan 16, 2012 | 12:49 AM
unless you have seen what the short ram a/f was doing on the dyno, you've got no say. as for the 2 degree i spoke of, it was to state the way it stays close to outside temp. did you miss the part where once you start rolling temps drop.intakes tend to change the pipe size, wich can go rich or lean.
Old Jan 16, 2012 | 12:52 AM
https://www.scionlife.com/forums/sho...ntake+shootout
Old Jan 16, 2012 | 12:56 AM
engifineer's Avatar
The reason the sri was having that effect is more likely due to turbulence from having the filter too close to the maf (a common issue with short rams), not because of anything else. And that is assuming your differences were real, not measured immediately after putting the sri on the car.
Old Jan 16, 2012 | 12:59 AM
Its just an intake. No matter how you look at it, there aren't any gains that are worth really writing home about. Takeda promised me 11 HP and torque. There's no way I'm getting that out of it. A CAI is a CAI is a CAI.
Old Jan 16, 2012 | 01:27 AM
Scion202's Avatar
All SRI/CAI = Sound, Looks, Tiny HP increase at high RPMs, HP decrease at low RPMs
Seems to me like all everyone should be looking for is the one that decreases the power at low RPMs the least haha
