PCV valve replacement
Old Jan 19, 2012 | 06:16 PM
afoulk's Avatar
Default PCV valve replacement
I have 17,000 miles on my 2011 xb and I'm getting ready to change oil. At what mileage do they recommend replacing the pcv valve in these things? and can i get one anywhere else besides the dealer? are they expensive? thanks.
Old Jan 19, 2012 | 09:33 PM
KiKaZ-tC's Avatar
You honestly probably shouldn't ever need to change your PCV valve, especially if you do your oil changes on time and you don't have any oil consumption issues.
If you do decide to switch out your PCV, i recommend going to the dealer to purchase it, i believe its under $10.
Old Jan 19, 2012 | 10:04 PM
CIONIDE's Avatar
MSRP is only $5.50 but I never needed to replace it on my 2008, and that xB was just traded in last month at 98k miles.
Old Jan 19, 2012 | 10:50 PM
xseveredveganx's Avatar
Utah Scions
New pics of new car. Now.
Old Jan 20, 2012 | 12:59 AM
afoulk's Avatar
Ok guys, thanks a bunch. I read the oil consumption poll and got a little worried. I'm only using about 1/4 to 1/2 a quart between oil changes, so no consumption issues yet, I just wanted to make sure I take care of the pcv system before it does cause me any problems.
Old Jan 20, 2012 | 01:16 AM
CIONIDE's Avatar
Nope, you have PM.
Old Jan 20, 2012 | 03:07 AM
RyanstC's Avatar
We usually recommend replacing them every 30k miles at my work and they are fairly cheap
Old Jan 20, 2012 | 03:21 AM
CIONIDE's Avatar
At only $5.50 each, I'm surprised Toyota doesn't include that in their maintenance schedule for 30k 60k 90k services if they should really be replaced that often.
Old Jan 20, 2012 | 03:26 AM
RyanstC's Avatar
They should list it in the maintenance book but they dont for some reason i think they put it under "inspect" on the list. Its good to replace it as a preventive maintenance measure though
Old Jan 21, 2012 | 02:31 AM
TrevorS's Avatar
Darn guys, no need to replace it, just flush it out with solvent (gasoline?) Unless the PCV valve is known to be a problem, it doesn't require any special treatment. (However, occasional attention is entirely appropriate!)
Old Jan 21, 2012 | 03:11 PM
kidd's Avatar
that's what i thought. it's a simple device. no reason it couldn't be cleaned with some kind of solvent.
Old Jan 22, 2012 | 05:26 PM
afoulk's Avatar
I used to just flush mine out with some brake clean like every other oil change but didn't know if that was enough. Its the valve on the back side of the valve cover, correct?
Old Jan 22, 2012 | 10:00 PM
xbscion's Avatar
The PCV valve is on the pass. side (looking from the front of the car) back of the engine valve cover. There is a rubber hose with a spring connector that you can remove with just your fingers. You can remove the engine cover or just feel back there and do the job, I recomment removing the cover since it's easy and makes the job more visible.
Since the price is between $5/10 dollars depending on where you buy it, I would just replace it and not bother trying to clean it.
Old Jan 23, 2012 | 12:52 AM
Roller_Toaster's Avatar
A quick spritz with brake cleaner nearly always does the job.
1/2 full can of brake clean in your garage + a 1 second spray = free
Buying a new pcv valve = gas to drive to dealership + price of part
What can I say, I'd rather fix it if it's fixable and save the gas.
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
cid_mcdp
Jan 5, 2015 02:45 PM
