Scion xD ICE & Interior In-car entertainment and electronics...
09 xD Pioneer Premium Aux/iPod button not working.
Old Feb 3, 2012 | 11:35 PM
filipinoXD's Avatar
Default 09 xD Pioneer Premium Aux/iPod button not working.
Hey everyone, I just bought a 09 xD and I love the car, however for some reason the aux/ipod button on the head unit wont work. Ive tried 2 third generartion iPods and a iPhone4.
but even when I plug it up with the iPod jack I still get nothing, even using the steering wheel mlde selector does nothing. Any advice?
I have the premium pioneer head unit.
Old Feb 4, 2012 | 12:02 AM
gjpjr84's Avatar
how are you connecting it?
USB to dock connector or auxillary?
if you just bought it then you could try going back to where you got it and tell them it doesn't work and check that the wires in the back are all plugged in.
could be a bad usb to dock connector cable.
Old Feb 4, 2012 | 12:47 AM
filipinoXD's Avatar
Im using the ipod jack connector with the pins, but no use. The button itself on the head unit doesnt respond at all. Plugged in or not I get nothing.
Still figuring out afew tricks about my XD thought it only was capable of ipod and the aux jack.
Old Feb 4, 2012 | 01:15 AM
gjpjr84's Avatar
i mean, is it the normal usb ipod cable or is it a big plug to the dock connector?
if nothing is plugged into the usb then hitting the ipod/aux button isn't going to make anything happen.
if you plug it in with the AUX headphone cable then you have to control the ipod yourself, it isn't going to be controlled through the HU.
if it is a big plug to the dock connector then an iPod touch or iPhone won't work quite right. apple changed the dock connector pins for the iPod touch and iPhone, you'd need a dock adapter, even then i think an iphone needs to be set to a certain mode for it to work fully.
the classic and mini ipods with dock connectors should work through the HU.
if you use a regular usb plug then it should work through the HU,
if not the cables are either not connected right or any of the cables might have gone bad for some reason, the ones coming from the HU or your usb cable.
Old Feb 4, 2012 | 01:26 AM
filipinoXD's Avatar
At the risk ofsounding like an idiot. Theres a usb port? only seen the aux jack and ipod connector. Been trying to get the ipod to work by using the big black ipod connector but not having any luck. The ipod is a third gen touch, so that may be the issue as you stated.
Old Feb 4, 2012 | 01:44 AM
gjpjr84's Avatar
i couldn't remember what year they changed it. scion used to use their own cord, which is the big plug to the dock connector, at some point apple changed the way the dock connector could work on the iPod touch and the iPhone. this change "broke" the ability to work with the old big plug to dock connector cord for those new iPod touches and iPhones and maybe the new touch screen nanos (classic ipod still works)
when the new model years were released scion/toyota stopped using their own plug and started putting in USB ports instead so you had to use your own usb to dock cords.
if you push the AUX/iPod button and use an AUX cord (headphone plugs on both ends) and plug that in to the car and ipod you have to select your music and hit play on the ipod and control the ipod itself. it isn't going to be controlled from the head unit.
if your using the included black cable and you want to use an ipod touch or iPhone, you need to get something like this:
Amazon Amazon
otherwise it isn't going to work like expected.
if you try to use an older ipod classic/nano or using the AUX through the ipod's headphone jack and it still doesn't work then the cables are either loose/disconnected or it is broken.
Old Feb 4, 2012 | 01:48 AM
filipinoXD's Avatar
Ahh I see now. If I want to control the ipod through the head unit I need that adapter correct? Could this be found at local stores ie bestbuy, radio shack etc.
Old Feb 4, 2012 | 03:27 AM
gjpjr84's Avatar
i should be, I am not sure, you would have to find out where/if it is available in your area yourself.
Old Feb 5, 2012 | 10:18 AM
kervin204's Avatar
instead of using USB/AUX try to do Bluetooth if its build it
Old Feb 7, 2012 | 03:08 AM
Swbari00's Avatar
I believe Scion used their own plug and an AUX input up until '09. In '09 they started using an AUX and a USB connection.
If you have the Scion connector you probably don't have an '09.
Apple switched a couple of the wires around (charging wires I believe) so the newer stuff won't charge on the old Scion connection without an adapter. But it should (most of the time) still work.
If you cannot get the AUX to work either (with a cable plugged into the AUX plug) then it is very likely the radio.
Old Feb 7, 2012 | 03:47 AM
filipinoXD's Avatar
I can get the aux to work with the ipod just fine but the jack connector doesnt respond. Think ill have to just go ahead and get the adapter.
Old Feb 7, 2012 | 04:08 AM
Swbari00's Avatar
i would skip the adapter for right now. That shouldn't be a problem. Make sure you try it out on older iPods/iPhones first. Otherwise you are wasting money. Make sure it isn't a cable problem first.
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Denzel
Oct 14, 2015 10:15 PM
Geedavell
Sep 28, 2015 01:33 AM
user9430961
Sep 24, 2015 01:09 PM
dyenfd
Sep 13, 2015 10:00 PM
