Scion FR-S Forum - The Scion sport coupe
Car and Driver Compares the FR-S and BRZ
Old Feb 21, 2012 | 11:57 PM
Jon's Avatar
Jon
Moderator
Moderator
Default Car and Driver Compares the FR-S and BRZ
In a nutshell the FR-S is easier to get sideways while the BRZ understeers.
http://www.caranddriver.com/features...ntrast-feature
The strut-front and multilink-rear suspensions have been adapted from the Impreza, and both cars have the same electrically assisted steering. Throw large inputs into their quick racks, and the cars ricochet back and forth, your body held in place by supportive seats. Both cars demonstrate remarkable body control and change course so quickly that you’d think they could slalom the lane-marker lines on an interstate at 85 mph. They probably couldn’t: The charitable among us would describe the Michelin Primacy HPs’ grip as underwhelming. Toyota chief engineer Tetsuya Tada tells us, “They are Prius tires,” and he’s not joking—they’re identical to those in the Toyota hybrid’s top trim level (outside the U.S.), right down to the compound and construction. Mark that down as Toyota’s second big donation to the project.
Those wimpy tires, however, contribute to the fun. Their deliberately tenuous grip encourages drivers to explore the cars’ limit behavior. Tada boasts that these cars are largely a reaction to the advanced technology and high-grip tires that have become synonymous with the modern sports car. The Primacy HPs’ easy breakaway characteristics make for a playful demeanor.
At the limit, you’ll find the key difference between the Subaru and the Scion. Go screaming into a turn or hop on the gas too early exiting one, and the Subaru simply understeers—perhaps for the benefit of drivers familiar with the brand’s all-wheel-drive products. The Scion uses softer springs and stiffer shocks, and it has a sensitivity to driver inputs that makes it feel alive. Too much or too little throttle upsets the Scion’s balance, sending the car into an easily controlled drift. Its behavior reminds us of the dearly departed first-generation Honda S2000. It’s not impossible to get the Subaru to oversteer—deliberately timed and moderated inputs will coax the tail out—it’s just not going to catch you by surprise. In either car, though, the transition from cornering to drifting is gradual, and the low curb weight—about 2800 pounds—helps make it easy to rein in a slide before you tailwhip your neighbor’s mailbox.
Old Mar 2, 2012 | 06:31 PM
highvoltage1's Avatar
Good read! Thanks for the post Jon.
kahsperr
Regional - Pacific South
Jan 3, 2015 04:26 AM
JonathonK
Autosports & Technique
Dec 17, 2014 07:13 PM
minter66
Dec 15, 2014 01:45 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
tC_Normo
Oct 22, 2003 07:20 PM
