Cig lighter turns off with key
Old Mar 29, 2005 | 02:18 AM
siclmn's Avatar
Default Cig lighter turns off with key
Why does it do that? How can I charge my cell phone when the key is off?
Old Mar 29, 2005 | 02:21 AM
Torokun's Avatar
um...
so you don't accidently leave off something plugged into your car and drain the battery...
Old Mar 29, 2005 | 02:22 AM
dgHotLava's Avatar
moved...
Old Mar 29, 2005 | 02:29 AM
pdrizzle's Avatar
DeepSouth Scions
You'll have to rewire your lighter to a constant power source. I don't know of one without looking at a wiring diagram, but it is easy to run a wire from your battery through the firewall. I hear some dealerships will do it, for a price.
Old Mar 29, 2005 | 02:35 AM
crayonBOX's Avatar
i believe all cars' cig lighters turn off; unless it's marked as a "power outlet"...then it's not supplied w/a cig lighter coil.
the best way to run a car charger (especially if you dont plan to take it out) is to hard wire it somewhere in your center console (same as i did with my radar detector);
otherwise, hardwire your cig lighter ( you can easily find a wire (20 amp +) in the fuse box under/to the side of the steering column)
~tesh
Old Mar 29, 2005 | 02:43 AM
basilisk4's Avatar
Exclusive
Not all cars do this, but it is pretty common.
Old Mar 29, 2005 | 02:46 AM
Mainrodax's Avatar
does anyone know for sure if it completely cuts off all power? I am worried about using it as a power source for something that always has a small power draw.
Old Mar 29, 2005 | 12:54 PM
dgHotLava's Avatar
if it cuts off the power, its complete...i don't understand how it could partly cut off power...
if its off...its off...no power what-so-ever....
ShawnMcc
Jul 11, 2015 11:07 PM
skruff
Jun 17, 2015 12:01 PM
setpol
Feb 17, 2015 11:33 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Kiwibox
Dec 15, 2014 09:46 PM
