Custom Fiberglass Enclosure
Old Mar 19, 2012 | 10:44 AM
qbnlykwhoa's Avatar
Default Custom Fiberglass Enclosure
This is my first time fiberglassing anything and wanted to show you guys what I did and get your opinions on it. I used a bazooka sub enclosure and gutted the insides. I then cut a good portion of it off and went to town with the resin and cloth. This thing got heavy quick and is very strong. I finished it all up by wrapping it up in some carpet. It's holding a 10" Boston Acoustics G310-44 subwoofer and is being powered by a Rockford Fosgate P500-1bd.
I don't have many in progress shots since my hands were pretty busy the whole time.
Old Mar 19, 2012 | 05:38 PM
hnyuH_divaD's Avatar
Looks great, good job! Know the cf?
Old Mar 19, 2012 | 05:50 PM
qbnlykwhoa's Avatar
Thanks man. The CF? Carbon Fiber?
Old Mar 19, 2012 | 06:59 PM
Tshock's Avatar
cubic feet
Old Mar 19, 2012 | 07:26 PM
qbnlykwhoa's Avatar
Originally Posted by Tshock
cubic feet
LOL, no not yet. I didn't have any packing peanuts or anything. Its pretty tight in there. I also have some closed cell foam inside lining the walls which really makes a difference. I will be measuring it this weekend and filling or removing foam as need be.
Old Mar 20, 2012 | 01:18 AM
t_C's Avatar
t_C
Very nice for a first attempt. From just the picture, and if I didn't know any better I'd believe it was a mass produced stealthbox or similar.
Starting with the bazooka tube gave you a nice even surround effect, and I bet it was a ton easier to get it spotted in the position you wanted.
Again, great work!
Old Mar 23, 2012 | 12:41 PM
qbnlykwhoa's Avatar
Well technically it was my second attempt. The first time the ring wasn't flush and my measurments were off some so I had a hard time screwing the sub into the enclosure. This time I triple measured everything and took my time. Well it took about two days to get it all done.
This is what it looked like the first time around, but it just wasn't good enough:
I will have to say that one of the hardest things is mixing the resin and hardener properly. During the morning it was cold and it was taking longer to cure giving me more time to work with it. Once the sun came out and it started to get warm the resin was hardening in the mixing cup before I could apply it all. I had to keep adjusting the amount of hardener I was using.
Now I have the itch to make another. Or maybe make some kick panels or sail tweet pods.
This weekend I will be deadening the hatch, trunk, doors, and rear panels as well as installing some Polk DB6501 components in the front.
Old Mar 23, 2012 | 01:06 PM
karmajack's Avatar
Loving your box. Fiberglass is beyond my skill level at this point. Not to mention I lack a proper workspace and tools to attempt such a thing. I'll end up buying a similar one some day. I would just need to have a grille for mine which I can't do with my current old school Kicker Solo s10d and the boxes out there. Not to mention getting the propper airspace correct on a low tollerance speaker. When I update, I can progress.
Anyway... Keep us posted on this project. I love watching stereo projects. I'm going to be putting in some infinty components later this month, and I'm always curious to see where/how people mount the crossovers and tweeters in he door. Sooo pics of those things would help me out if you could.
Old Mar 23, 2012 | 01:44 PM
Tshock's Avatar
good job on not settling with your first one. patience makes a huge difference and can be seen on people's cars.
Old Mar 23, 2012 | 01:46 PM
qbnlykwhoa's Avatar
I ordered a Polk grill for it which hasn't come in yet. Hopefully it fits. The BA G310-44 sub I have has an extra large surround which sticks out pretty far. I haven't put anything in the trunk since I installed it. Don't want it getting damaged.
There does seem to be a lack of DIY's or walkthroughs of the door panels for crossover installs. I will try my best to snap some shots when I do it. I usually end up getting so into it that I don't take any pictures just to finish faster. I wish I would have taken some pictures of the enclosure fabrication stages. I was so excited that I used every minute working on it and did not snap any shots.
Old Mar 23, 2012 | 01:47 PM
qbnlykwhoa's Avatar
Thanks, I was going for a particular look which I did not achieve on my first build. Second one is spot on to what I wanted. Very happy with the results.
Old Mar 23, 2012 | 06:39 PM
Tshock's Avatar
Sweet, now go deaden those rear quarters all the way to oblivion and back.
Old Mar 26, 2012 | 05:28 PM
qbnlykwhoa's Avatar
Progressed a little this weekend, didn't have too much time...
Built a rack to mount the amps on and deadened the hatch and trunk floor.
Deadened real good behind the sub enclosure and all the way to the outer body panels. I only have 50 sq ft of Audio Technix using it conservatively. Still want to wrap the front doors. In the back alone I used about 20 sq ft.
I also deadened inside the enclosure a little just to try it out and the results sound great.
I took the door panel off and I was playing around with crossover location and I think I am going to mount them behind the kick panel/under dash area. It's easier and If I want to adjust the crossover I don't have to take the door panel off. Running the cable through the rubber grommet was another pain in the ___ until I realized you can unplug the cables and pull the grommet out. I only got one woofer in and wired it to radio power for now. Will hook the crossovers and other components up this weekend.
These are the pictures I have so far.
One thing I notice too is a high pitch squeal coming from the rockford amp. It's coming from the amp itself and not the speakers so I don't know if the distribution block is the culprit. You can't hear it from the front especially with the floor back on but I know it's there and wasn't there before.
Enough babble, here are some pictures...
Old Mar 26, 2012 | 11:19 PM
chubbykai's Avatar
Aw man that amp rack is way to cool!
Old Mar 27, 2012 | 12:07 PM
karmajack's Avatar
Yeah the rack set up is looking super clean. Great craftsmanship. Keep us posted. I wanna see some component install process pics.
Old Mar 31, 2012 | 07:24 PM
Isotopian's Avatar
Your amp rack looks phenomenal. I'm in the middle of a similar build, and was contemplating fiberglassing the floor area, but I think I might follow your lead here, looks much simpler and more functional. Well done sir.
Old Apr 1, 2012 | 07:12 AM
Rawrtc's Avatar
Your second enclosure looks more custom, it's awesome. I love your amp rack. Stealthy and keeping your spare Encourages me to try and make a box too!
Old Apr 3, 2012 | 03:16 PM
qbnlykwhoa's Avatar
Thanks guys..
I started mouting the components and ran into some issues with the kenwood amp so right now they are running off of the HU. They sound very nice for just being powered by the HU. I decied to place the crossovers under dash above the kickpanels and just runt he cables into the doors. Makes like easier. Will have pics of that once they are all hooked up and functional.
In the mean time I started making some custom sails to mount the tweeters. The tweeters can swivel in the mount. Should have them finished, painted, and mounted by the weekend. Below you will see them covered in a layer of glazing spot putty. Thank god for my mouse sander
Old Apr 4, 2012 | 03:46 AM
brandaman50l's Avatar
great job man! i needa learn how to do this!
Old Apr 5, 2012 | 04:48 AM
qbnlykwhoa's Avatar
Worked on them a little more today. Some more sanding and first coat of primer. Didn't have too much time. Probably finish them this weekend.
SloTC1
Aug 16, 2018 02:45 PM
neneago
Oct 27, 2015 04:47 PM
torqueTc
Oct 8, 2015 05:39 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Btp907
Sep 15, 2015 02:54 AM
