Are these Volks too wide? 18x7.5 ET+40
Old Apr 19, 2012 | 10:08 PM
Jeremy8778's Avatar
Question Are these Volks too wide? 18x7.5 ET+40
Found a very good deal but I am not sure if they will fit.
Volk GT-F (2 piece)
18x7.5 / ET+40
4x100 / 23lbs
225/40 18" Tires
For $400
Now using the calculator online I can see these tires are too wide.
  • Inside: 20 mm (0.8'') closer to suspension/brakes
  • Outside: will stick out 30 mm (1.2'')
If I switch to 205/40 18" tires I get the following:
  • Inside: 10 mm (0.4'') closer to suspension/brakes
  • Outside: will stick out 20 mm (0.8'') farther
Do you think that will work? I have no experience at this and My iQ is in transit so I can't measure yet. Even if they fit do you think 23lbs is too heavy? Thanks for any info!
Rim/Tire Calc:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Volk GT-F:
Old Apr 20, 2012 | 12:53 AM
emrules2001's Avatar
A roll/slight pull on the fenders will work if they arent the right size. Cut to fit, paint to match!
Old Apr 20, 2012 | 03:56 AM
Pannyman's Avatar
Huge fan of volks, I am either leaning towards stock rubber and lightweight rim and go from there otherwise 17" rim under 30lbs; I believe and i know someone will correct me that a pound a rim is equal to 10lbs stationary weight; so if I save 4lbs per rim that should be a 120lb difference; brakes are really nice but if you do get them let me know how it is; i would just prefer to not spend too much money
23 pounds seems a little heavy but consider its a 18" rim its very lightweight in that regard to others; i try to stay under 20 lbs but are you going for looks or performance; that is what it comes down to; sorry I rambled
Old Apr 20, 2012 | 05:50 AM
Jeremy8778's Avatar
I found another guy that is already running 245/40 18 on lowering springs with no problem. My 225/40 18 will be fine and I don't have to buy new tires! Not sure if he is on this forum but his car is linked below.
Vancouver IQ - Get Low
I already have ideas on painting to match but I have to wait and see the car first! Should be here next week and I get the Volks on Wed. My last stock wheels only saw 1000miles and this one may be even less!
Old Jul 12, 2012 | 05:48 PM
alejandrollerena's Avatar
stretching tires is the way to go with these cars use the stock tires that they come with and stretch them to about 8 inches look at my post its xxr 530 16 x 8 I'm using 8 inch wide tires and man does the car get a mean look to it.
mischman
Sep 15, 2015 03:38 PM
rvascion
Scion xB 2nd-Gen Wheel & Tire
Aug 16, 2015 02:26 AM
vancouverray
Aug 14, 2015 11:47 PM
umnitza
Jul 25, 2015 07:54 PM
KAuss
13
Apr 5, 2004 06:46 AM
