Maintenance schedule -- first oil change at XXXX miles?
Hey guys, I spoke to SCION service center the other day and they said the first oil change is due @ 5000 miles, I always thought it was after the run-in period?
Originally Posted by jmiller20874
It's recommended that you get it done after break-in but it's not required.
Ok, maybe I shoulda phrased that a little differently.
It's generally accepted that you get the oil changed after break-in....blah, blah, blah :D
had mine done at 600 miles and again at 2,500. Now I'm at 5,600 and I'm getting it changed again, then every 3,000 from here on out. It doesn't cost me anything, so it doen't hurt.
When I picked up my plates I stayed for an oil change. I was at 950miles and decided to go for it. I dont know when my next change will be but I would say ...around 4500. Hope that helps. . . . If you aren't paying for your firs 3 changes, do it righter then you normally would.
i'd definetely suggest getting one done within the first 500-1000 miles, as your engine and pistons break in, you dont want any small shaving of metal to be floating around in your oil.
DaBlackBox
134
Apr 10, 2022 02:04 PM
