L.S. Differential + clutch installation labor cost?
My mechanic, not feeling perfectly comfortable installing my LSD & clutch himself (I think he's being overly/ultra conservative here), got a quote from a place he usually trusts: $2000 to install the LSD and clutch. He trusts this place, and I respect my mechanic's judgment, but it nevertheless seems very steep to him and myself. The principle of the thing offends me, when I've seen much lower figures floating around the Internet, more in the range of $1000+/- a little. I even saw a dealership quote around $1400.
I called Descendant/World Racing today and they quoted me $900-$1000. I can't realistically take it there, however, as I live two states away.
Help/guidance/thoughts/direction, would be appreciated.
Thank you!
-John
Thank you!
-John
As I state in my original post, I live two states away from Descendant. I'm not driving to Descendant's location in California. What I'm looking for is ideas as to what you think it should cost. I'm not making any decisions until I get as thorough a sampling as possible as to what a typical charge would be for LSD + clutch installation.
http://www.ptuning.com/html/ptuning_...tch_servic.cfm
BTW, where did you find the LSD?
You should not have to pull the engine to change the clutch. Transmission yes, engine no. The internet is great but most of the information out there is garbage. Depending on where you live I'd say $1000-$2000 is typical. Have you looked at any of the diy threads on here for the install? I'm not saying you should try it but it will give you an idea of what the other guy is going to be up against.
I would drive two states away if it saved me $1,000 or more dollars. IMO if it's a serious mod I would definitely drive a ways to get it done by the shop that probably has the most experience modifying a tC...especially if that place was 1,000 bucks cheaper than the local mechanics. However, I don't know you're circumstances....but $2,000 is pretty steep. Personally though, I would study for a while and give it a go myself.
Yep sounds right, if the labor charge is about $100/hr., which is what many dealerships charge. I've checked with 3 Toyota/Scion dealerships, and received the same quote:
10 hours for the LSD install separately.
9 hours for the clutch install separately.
14 hours if performed together since the tranny only has to come out once.
DaBlackBox
134
Apr 10, 2022 02:04 PM
reagan9000
Jan 28, 2015 06:20 PM
Xaphoon
Jan 17, 2015 02:12 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
