tC: SOLD scion tc rs3 515+hp turbo road race/time attack/show car
Old May 12, 2012 | 07:20 AM
upStyles's Avatar
Default SOLD scion tc rs3 515+hp turbo road race/time attack/show car
This car has been built as a time attack/road race/street/show car. No expense ever spared. This car’s motor build is a replica of the PTUNING’S famous Time Attack car that was the 2008 and 2009 Red Line Time Attack FWD Class Champion. The dyno numbers of 515WHP show a pull at 22psi with no water/meth and on 93 pump gas. I did not want to do any more pulls until I broke in the motor…but never had the time to go back and re-dyno after the break in. With water/meth or race fuel this car can easily handle 650+WHP and 35+psi. All motor work was completed by PTUNING. I have attached a few of the invoices so you can see the amount of $$$ in the car and work. There is easily over $80,000 invested in this car.
The car was never raced and never seen a real car show (only local meets). It took years to build this car and unfortunately now that it’s complete I do not have any time to enjoy it with my current job. I am a business owner and have to focus on building up the business rather than spending time on the vehicle.
The car is in 100% perfect working condition. I am selling because I have no time to enjoy this car and it deserves to go to someone who will appreciate the build.
This car has the potential to be a track car, a show car, a daily driver…whatever you choose. The car was always babied and was barely driven in the past year.
Title is clear, no issues whatsoever. I am the original owner. The car was in one very minor fender bender about two months after I purchased it in 2007…lady hit my rear bumper at a red light…all it needed was a re-spray.
This is definitely a one-of-a-kind build. I have listed all the modifications as I can remember.
Please let me know if you have any questions. Serious buyers only please.
NUMBERS
· 515+ WHP on PTUNING Dyno Dynamics chassis dyno
o 22 psi
o 93 pump gas, NO water/methanol
· Capable of 650+ WHP with higher boost (psi) and water/meth or race fuel
o Did not dyno with water/meth or race fuel (wanted to break in motor first)
o Motor is able to handle 35psi +
ENGINE
· 2.4-liter 2AZ-FE turbocharged
ENGINE MODIFICATIONS
· PTUNING Spec-TA short-block
o Diamond honed ductile iron sleeves
o 9:1 CP forged pistons
o MANLEY Performance forged chromoly I-beam rods
o Lightened, balanced, and micro-polished crank
o Balance shaft elimination
o ARP head and main studs
o ACL rods, main, and thrust bearings
o COMETIC head gasket
· PTUNING Spec-TA cylinder head
o Ported and polished
o 5-angle intake and radius exhaust valve job
o SUPERTECH valve guides, stem seals, dual valvesprings, and titanium retainers
· PTUNING Spec-TA Turbo camshafts
· PTUNING Time Attack turbo system
o Stainless equal-length turbo manifold
o GARRETT GTX-3582 turbo with TIAL housing
o 3" aluminum intercooler piping
o TURBOSMART DUAL 40mm external wastegates
o TURBOSMART Race port blow-off valve
o Custom BELL intercooler
o PTUNING 4" aluminum intake w/ custom induction air box
o AEM Dryflow 6” cone filter with Hydro shield
o PTUNING boost solenoid
· PTUNING 3" stainless turbo-back exhaust system with custom Exhaust Tip
o Full 3" T304SS mandrel-bent tubing
o T304SS exhaust hangers
o T304SS lightweight V-Band connections
o Centralized-muffler design for better weight distribution
· PTUNING/A.R.E. dry sump oil system
o RED LINE oil
o GREDDY oil catch can
· Cooling system
o Custom RON DAVIS Racing radiator
o GREDDY Radiator breather tank setup
o SAMCO Radiator hoses
o SPAL radiator fans
· Fuel System
o PTUNING billet fuel rail, return-style fuel system and fuel surge tank
o Liquid filled 0-100 psi fuel pressure gauge
o FUEL LAB fuel pressure regulator
o WALBRO 255 internal fuel pump
o WALBRO 255-lph external fuel pump
o FUEL INJECTOR CLINIC 900cc/min injectors
o EARL’S Pro-Lite braided hoses
o NGK Iridium spark plugs
· PTUNING WATER METHANOL Injection kit w/ AEM pump
o AEM Progressive controller
o PWM to control pump speed (pressure)
o Integrated with factory washer system
o Integrated relay that can be used to turn off an electronic boost controller
o One-way check valve
o In-dash switch activated for system ON/OFF
· ODYSSEY lightweight racing battery
o Billet FiD Battery mounting kit
· LUX MOTORWERKS custom engine bay cover panels painted black
· PTUNING custom air intake boxes behind bumper vents for forced air induction
ENGINE MANAGEMENT
· HALTECH Standalone ECU Sport 1000
· Professionally tuned by Toan (PTUNING)
DRIVETRAIN MODIFICATIONS
· EXEDY Twin-Disc clutch and billet flywheel
o T5001 cerametallic friction materials for extreme heat resistance
o Rated up to 800+ foot pounds of torque at the flywheel
· OS GIKEN Limited Slip Differential
o Clutch type LSD
· Cryo treated gears
· DEZOD MOTORSPORTS Stainless Steel Braided Clutch Line
· B&M shifter
· RED LINE synthetic gear oil
· DRIVESHAFT SHOP 600HP Level 3.9 Axle/Hub Kit
SUSPENSION
· STANCE GR+ coilovers
· STANCE camber/caster plates
· ENERGY SUSPENSION Hyper-Flex Master Bushing Set
o Front control arms
o Rear trailing arms
o Front and rear sway bar bushings
o Rear sub frame bushings
· TRD front strut bar powder coated lime green
· HOTCHKIS Sport Suspension Sway Bars Front and Rear
o Front Bar - 15/16" (24mm) - 2 position adjustable
o Rear Bar - 1 1/16" (27mm) - 3 position adjustable
· PROGRESS Complete Alignment Kit
· DEZOD MOTORSPORTS V2.3 Competition Spec Rear Sway Bar Endlink Set
· INGALLS Front Sway Bar Endlinks
WHEELS / TIRES
· ENKEI RPF1 SBC 18x9.5 et38 (special order/custom offset)
· NITTO NT01 Road Race Radials
o 245/40/18 front
o 225/40/18 rear
· RAYS racing lug nuts
· OPTIONAL (NEW pair of drag radials with wheels, mounted and balanced)
o ADDITIONAL $1,000.00 to purchase price
o ENKEI RPF1 SBC 18x9.5 et38 (one pair – 2 wheels)
o NEW BF Goodrich G-Force R1 Drag Radials 245/40/18
BRAKES
· Front
o BREMBO Gran Turismo Drilled Big Brake Kit (Zinc Coated)
o “Floating” Disc Mounting System with Billet Aluminum Hat
o SS brake lines
o HAWK pads
o Powder coated lime green calipers
· Rear
o BREMBO drilled zinc coated rotors
o STOPTECH SS brake lines
o HAWK pads
o Lime green caliper powder coat
· MOTUL RBF 600 Brake Fluid
EXTERIOR
· RS3 Blizzard White Pearl Paint
· KAMINARI custom carbon fiber hood with custom mounting/brackets/venting
o DYNAMAT HOODLINER with additional coatings
· SPARCO Hood Pins with custom locking mechanism
· Dzus Fasteners/1/4 turn Quick Release Front Bumper setup
· Custom pulled and welded front fenders for +25mm clearance
· TRD carbon fiber license plate frame
· IS KENSTYLE lip kit (front and rear)
· RS3 LED Tail lights
· Shaved/deleted and filled rear hatch garnish (emblem delete)
· JP rear trunk lip spoiler with cutout
· S2000 Antenna
· Convex and blue tinted side mirrors
· Carbon fiber B-pillar covers
· RACING SOLUTION RS1 side skirts
· LIGHTWERKZ custom QUAD BI-XENON headlight retrofit conversion
o TFX Bi-Xenon projectors in the low beam area
o TSX Xenon projectors in the high beam area
o BMW E46 shrouds for all four projectors
o 55w HID kits in all four projectors (digital ballasts)
o 3000K yellow in the high beam projector area as “fog” light
o 4300k in the low beam projector as driving light/high beam.
· RS3 upper grill insert
· PTUNING custom drilled front bumper air vents for maximum cooling
· APR custom front wind splitter
· OZNIUM LED’s
o Under mirror courtesy lights (works with door unlock/lock)
o Door handle courtesy lights (works with door unlock/lock)
o Under side skirt courtesy lights (works with door unlock/lock)
§ Can also work independently as under glow lighting
· Sub frame, control arms, sway bars, tie rods, strut bars, valve cover, calipers, intake piping, etc. powder coated lime green
· LED license plate lights
INTERIOR
· Gauges (3 gauges in A pillar mount, 3 gauges in center top dash mount)
o DEFI Blue Racer Gauges
§ Boost, EGT, Volt, Water Temp, Oil pressure
o AEM UEGO Wideband 02 Gauge
o HKS Turbo Timer Type-1
o GREDDY PROFEC B SPEC 2 Electronic Boost Controller
· Gauge cluster conversion
o Tachometer moved to center position, speedometer moved to side position
o White Enzo style gauge faces with TRD logo
o Custom LED conversion to blue, white and red
· Full interior dash LED swap
o H-VAC, Radio controls, clock, mood lighting / interior lighting, etc.
· Custom Water/Meth Light indicator in dash (turns on when activated)
· Custom switch panel/board with switches for:
o Interior illumination / mood lighting (ON/OFF)
o Water/Meth system ON/OFF
o Secondary projectors ON/OFF
o Under body/courtesy lights ON/OFF with remote FOB or constant ON
· Stainless Dead pedal with tC logo
· OBX Stainless Pedals
· RS3 authentic shift **** – white
· RS3 Alcantera seats, front and rear
o Black/white
· Carbon Fiber interior trim package
· MITO Corp. Auto-dimming rearview mirror with Home link and custom LED Mood lighting
· Full tint
o 20% sides, rear and front strip
· TRD Logo embroidered floor mats
· OZNIUM LED’s
o Door panels
o Foot well (front and rear)
o Cup holders
o Dome lights (front, rear and trunk light)
AUDIO
· PIONEER AVIC D3 In-dash DVD receiver/Navigation system
o Blue tooth
o SAT radio
o Navigation
o NavTraffic
o Ipod connect
· JBL C608GTi-mkII 6-1/2" 2-way Component Speakers System Front and Rear (Rear tweeters mounted in C-Pillar)
o Power Handling
§ Peak: 1200 watts per set / 600 watts each side
§ RMS: 300 watts per set / 150 watts each side
o Frequency Response: 50Hz - 21kHz
o Sensitivity: 89dB
· MEMPHIS 15-MS104 10" Single MClass Subwoofer
· Custom fiberglass trunk subwoofer enclosure painted to match exterior
· JL HD1200/1 Monoblock Class D Wide-Range Amplifier (Subwoofer)
o 1200 W x 1
o Hidden in Quarter panels
· JL HD600/4 4-Channel Class D Full-Range Amplifier (Components)
o 150 W x 4
o Hidden in quarter panels
· DYNAMAT EXTREME (800 sq. ft.)
o Floor
o Doors
o Quarter panels
o Roof
o Firewall
o Fenders (partial)
o Trunk
o Hatch
o All pillars
o License plate
o Gas cap
Old May 12, 2012 | 07:24 AM
upStyles's Avatar
Size:  25.9 KBName:  IMG_0253.jpg
Size:  39.9 KBName:  IMG_0235.jpg
Size:  49.2 KBName:  IMG_0233.jpg
Size:  50.6 KBName:  IMG_0257.jpg
Size:  29.7 KBName:  IMG_0272.jpg
Size:  73.3 KBName:  IMG_0274.jpg
Size:  69.0 KBName:  IMG_0275.jpg
Size:  72.2 KBName:  IMG_0276.jpg
Size:  85.8 KBName:  IMG_0278.jpg
Size:  27.1 KBName:  IMG_0282.jpg
Size:  53.3 KBName:  IMG_0283.jpg
Size:  75.1 KBName:  IMG_0286.jpg
Size:  30.1 KBName:  IMG_0289.jpg
Size:  57.0 KBName:  IMG_0294.jpg
Size:  80.9 KBName:  IMG_0296.jpg
Size:  66.7 KBName:  IMG_0298.jpg
Size:  68.3 KBName:  IMG_0301.jpg
Size:  53.5 KBName:  IMG_0306.jpg
Size:  71.4 KBName:  IMG_0309.jpg
Old May 12, 2012 | 07:27 AM
upStyles's Avatar
Size:  73.3 KBName:  IMG_0313.jpg
Size:  36.4 KBName:  IMG_0315.jpg
Size:  32.8 KBName:  IMG_0318.jpg
Size:  59.9 KBName:  IMG_0324.jpg
Size:  66.4 KBName:  IMG_0325.jpg
Size:  68.1 KBName:  IMG_0329.jpg
Size:  44.7 KBName:  IMG_0331.jpg
Size:  42.2 KBName:  IMG_0336.jpg
Size:  69.0 KBName:  IMG_0338.jpg
Size:  43.2 KBName:  IMG_0341.jpg
Size:  57.7 KBName:  IMG_0345.jpg
Size:  76.7 KBName:  IMG_0346.jpg
Size:  67.3 KBName:  IMG_0347.jpg
Size:  74.6 KBName:  IMG_0352.jpg
Size:  56.1 KBName:  IMG_0353.jpg
Size:  66.4 KBName:  IMG_0356.jpg
Size:  72.7 KBName:  IMG_0362.jpg
Size:  63.0 KBName:  IMG_0372.jpg
Size:  84.9 KBName:  IMG_0381.jpg
Size:  64.9 KBName:  IMG_0396.jpg
Old May 12, 2012 | 07:31 AM
upStyles's Avatar
Size:  60.1 KBName:  IMG_0402.jpg
Size:  27.5 KBName:  IMG_0407.jpg
Size:  55.7 KBName:  IMG_0408.jpg
Size:  33.5 KBName:  IMG_0409.jpg
Size:  31.7 KBName:  IMG_0420.jpg
Size:  11.3 KBName:  IMG_0421.jpg
Size:  15.4 KBName:  IMG_0422.jpg
Size:  65.4 KBName:  IMG_0426.jpg
Size:  67.0 KBName:  IMG_0428.jpg
Size:  72.8 KBName:  IMG_0430.jpg
Size:  46.7 KBName:  IMG_0440.jpg
Size:  46.4 KBName:  IMG_0442.jpg
Size:  59.3 KBName:  IMG_0449.jpg
Size:  49.2 KBName:  IMG_0454.jpg
Size:  63.1 KBName:  IMG_0456.jpg
Size:  47.2 KBName:  IMG_0463.jpg
Size:  51.7 KBName:  IMG_0467.jpg
Size:  37.1 KBName:  IMG_0471.jpg
Size:  49.5 KBName:  IMG_0476.jpg
Size:  53.5 KBName:  IMG_0483.jpg
Size:  55.6 KBName:  IMG_0484.jpg
Size:  56.6 KBName:  IMG_0490.jpg
Old May 12, 2012 | 07:35 AM
upStyles's Avatar
Size:  47.4 KBName:  IMG_0494.jpg
Size:  61.6 KBName:  IMG_0502.jpg
Size:  62.0 KBName:  IMG_0506.jpg
Size:  52.2 KBName:  IMG_0508.jpg
Size:  37.6 KBName:  IMG_0511.jpg
Size:  37.7 KBName:  IMG_0513.jpg
Size:  47.4 KBName:  IMG_0516.jpg
Size:  51.0 KBName:  IMG_0519.jpg
Size:  24.8 KBName:  IMG_0523.jpg
Size:  30.5 KBName:  IMG_0527.jpg
Size:  42.3 KBName:  IMG_0537.jpg
Size:  44.5 KBName:  IMG_0541.jpg
Size:  42.0 KBName:  IMG_0543.jpg
Size:  35.0 KBName:  IMG_0547.jpg
Size:  44.0 KBName:  IMG_0553.jpg
Size:  21.9 KBName:  IMG_0554.jpg
Size:  39.5 KBName:  IMG_0558.jpg
Size:  50.1 KBName:  IMG_0559.jpg
Size:  43.8 KBName:  IMG_0561.jpg
Size:  43.7 KBName:  IMG_0571.jpg
Size:  52.0 KBName:  IMG_0573.jpg
Size:  50.7 KBName:  IMG_0576.jpg
Size:  56.7 KBName:  IMG_0581.jpg
Size:  46.9 KBName:  IMG_0585.jpg
Old May 12, 2012 | 07:39 AM
upStyles's Avatar
Size:  54.9 KBName:  IMG_0605.jpg
Size:  35.4 KBName:  IMG_0617.jpg
Size:  38.2 KBName:  IMG_0619.jpg
Size:  39.4 KBName:  IMG_0627.jpg
Size:  40.3 KBName:  IMG_0634.jpg
Size:  36.0 KBName:  IMG_0637.jpg
Size:  28.4 KBName:  IMG_0643.jpg
Size:  54.4 KBName:  IMG_0642.jpg
Size:  55.5 KBName:  IMG_0657.jpg
Size:  55.1 KBName:  IMG_0665.jpg
Size:  42.3 KBName:  IMG_0667.jpg
Size:  41.1 KBName:  IMG_0678.jpg
Size:  40.6 KBName:  IMG_0681.jpg
Size:  45.5 KBName:  IMG_0684.jpg
Size:  42.0 KBName:  IMG_0691.jpg
Size:  51.9 KBName:  IMG_0700.jpg
Size:  37.1 KBName:  IMG_0724.jpg
Size:  23.7 KBName:  IMG_0741.jpg
Size:  31.4 KBName:  IMG_0748.jpg
Size:  19.0 KBName:  IMG_0750.jpg
Size:  16.1 KBName:  IMG_0754.jpg
Size:  29.5 KBName:  IMG_0762.jpg
Size:  12.9 KBName:  IMG_0758.jpg
Size:  25.0 KBName:  IMG_0765.jpg
Size:  11.6 KBName:  IMG_0774.jpg
Old May 12, 2012 | 07:46 AM
upStyles's Avatar
Size:  49.2 KBName:  IMG_0779.jpg
Size:  70.0 KBName:  IMG_0780.jpg
Size:  55.4 KBName:  IMG_0783.jpg
Size:  47.5 KBName:  IMG_0787.jpg
Size:  34.7 KBName:  IMG_0790.jpg
Size:  35.0 KBName:  IMG_0793.jpg
Size:  49.7 KBName:  IMG_0794.jpg
Size:  55.9 KBName:  IMG_0795.jpg
Size:  50.1 KBName:  IMG_0796.jpg
Size:  50.7 KBName:  IMG_0798.jpg
Size:  48.9 KBName:  IMG_0800.jpg
Size:  46.6 KBName:  IMG_0802.jpg
Size:  52.5 KBName:  IMG_0806.jpg
Size:  48.8 KBName:  IMG_0815.jpg
Size:  51.4 KBName:  IMG_0818.jpg
Size:  46.2 KBName:  IMG_0820.jpg
Size:  48.3 KBName:  IMG_0821.jpg
Size:  61.5 KBName:  IMG_0824.jpg
Size:  47.6 KBName:  IMG_0826.jpg
Size:  45.0 KBName:  IMG_0835.jpg
Size:  50.0 KBName:  IMG_0846.jpg
Size:  49.4 KBName:  IMG_0855.jpg
Size:  47.8 KBName:  IMG_0849.jpg
Size:  45.1 KBName:  IMG_0873.jpg
Size:  60.3 KBName:  IMG_0880.jpg
Size:  50.4 KBName:  IMG_0889.jpg
Size:  44.5 KBName:  IMG_0898.jpg
Size:  35.8 KBName:  IMG_0893.jpg
Size:  42.1 KBName:  IMG_0932.jpg
Size:  62.7 KBName:  IMG_0952.jpg
Size:  61.8 KBName:  IMG_0969.jpg
Size:  58.7 KBName:  IMG_0982.jpg
Size:  50.8 KBName:  IMG_0986.jpg
Size:  61.5 KBName:  4-final.jpg
Size:  92.2 KBName:  5-final.jpg
upStyles's Avatar
For more pics look here....
http://photobucket.com/tcforsale
Old May 12, 2012 | 02:25 PM
Ace83's Avatar
Ronin Scion
one of my fave build in SL!
Old May 12, 2012 | 03:00 PM
TRD93's Avatar
Now that right there is a build wow Good luck with sale
Old May 12, 2012 | 03:33 PM
Yay Jaw Knee's Avatar
WOW... Perfection!!
Old May 12, 2012 | 06:46 PM
emrules2001's Avatar
That thing is a piece of art
Old May 13, 2012 | 01:51 AM
my06tc's Avatar
why cant the scions come stock like this lmao lol
Old May 14, 2012 | 12:00 AM
x_Batman_x's Avatar
holy ****.
How have I never seen this car before? I am sad that my introduction to this piece of art has to be in a For Sale thread. Seriously, the style of this build is right up my ally. This is a perfect blend of performance and aesthetics. This is the same mentality that I strive to achieve with my own car.
This may just be my favorite car that I have ever seen on ScionLife. Congrats on such a well thought out and well executed build. Again, I am sad that I didnt know this car sooner, and I hope who ever buys it enjoys it as much it deserves.
Old May 16, 2012 | 12:35 AM
my06tc's Avatar
i would def buy this in a heart beat,the perfect well built scion ive ever seen,
Old May 19, 2012 | 06:06 PM
runk2776's Avatar
If the car is still around, I'm in Jersey as well id love to come see it sometime. I drive an 08 white tc that looks similar but has none of the performance work put into it. I just love the car and saw that your in the area, if it hasn't sold yet and you are willing, id love to come check it out sometime it's a beautiful car. email me at runk2776@gmail.com
Old May 24, 2012 | 07:44 AM
DeAnzaJig's Avatar
holy......crap......EXCELLENT work
Old May 24, 2012 | 01:16 PM
andrew_ptuning's Avatar
You guys should see his S2k we built also.
Old May 26, 2012 | 02:02 PM
upStyles's Avatar
Thank you everyone for the kind words...i hope someone buys this car and appreciates all of the work done to it...
its back up on ebay....http://cgi.ebay.com/ebaymotors/ws/eB...t_11498wt_1182
Old May 27, 2012 | 02:25 AM
jchris315's Avatar
only if i had 35g laying around! i like the custom green
