Horn Help Needed
Old Jun 29, 2012 | 12:59 PM
MassiveAttack's Avatar
Default Horn Help Needed
Sorry of this belongs in the DIY forum.
Bought an 04 xB used, and the car has several mods. Some work, others didn't, and I fixed some.
The problem I need help with is the horn doesn't work. If I press the steering wheel horn, no sound. If I press the panic button on the key fob, all of the lights blink, but no sound.
So I pulled out the manual and checked the fuse, but it looks good. Any suggestions for me to test? Also, I
could use a working link to pix of the horn locations, if anyone has them.
Thanks
Old Jun 29, 2012 | 02:38 PM
Caprice0083's Avatar
Thanks
there are 2 horns on the xb. one is on the driver side under the fender, and one is smack dab in the middle of the bumper, right above the radiator. Sorry, didnt find any pics.
Old Jun 29, 2012 | 03:46 PM
Reactor's Avatar
Pull out the horn relay from under the hood and jump the terminals #3 and #5. See if that makes the horns work.
Old Jun 29, 2012 | 04:49 PM
Default Thanks Reactor and Caprice0083
Thanks guys, I'll try the jumper trick this evening, and post back later.
Old Jun 29, 2012 | 08:08 PM
Tomas's Avatar
Admin Emeritus
Might want to grab some of this info, too, from my info site...
http://scionlife.org/Scion_Docs/2004_xB_Shop_Manuals/
(Image from here.)
Old Jul 8, 2012 | 09:24 PM
Default Still No Luck
Sorry for the long delay. As you may have heard, high winds from a storm knocked out power for a lot of central Ohio. My car was stuck inside a garage with no other doors than the (un)powered overhead door for four days! After freeing it, I was able to work on some things.
Thanks for the suggestion to jump terminals #3 and #5 under the Horn Relay, Reactor. I used Tomas's diagram to figure out which relay to pull. Unfortunately there is no horn sound when directly putting a wire into both terminals.
Looks like I'm going to have to get some professional diagnostics performed.
Thanks again guys
Old Jul 9, 2012 | 03:46 PM
Reactor's Avatar
Replace the HORN fuse under the hood.
Old Sep 30, 2012 | 05:43 AM
I was getting a brake job done at a local shop, and I asked the guys to check out my horn. I told the mechanic that I had an alarm system and he said that he has seen this issue several times. "People have alarm systems and the alarm may go off all night long and the horn just burns out." I mention that the xB has two horns and he says, "I know, and the horns are in series, so if one burns out the other won't work."
They installed an $18 horn and charged me a half hour's labor. Now I can honk at the 2-3 people a week who almost run me off the road!
Sent from my iPad using Tapatalk HD
debris
Mar 13, 2015 08:15 AM
blh72
Jan 31, 2015 03:41 PM
miniamd95
Jan 22, 2015 09:38 PM
rancur3p1c
Dec 19, 2014 04:30 PM
XB_2
Nov 23, 2014 02:48 PM
