dual amps
ok my buddy is going to add to his setup in the form of another amp.
hes got 2 12s powered off one as of now. his plan is to have one amp power a sub of its own.
so that means sub A gets an amp and sub B gets an amp
what we need to know is how do we connect 2 amps to one head unit? special plugs?
it should go
HU>>amp(A)+sub & amp(B)+sub. but how?
any help would be awsome.
any added tips would be cool too
it should go
RCA Y cable is pretty much the simplest way to do it, unless the amp you have has an RCA in and out, (in from the deck out to another amp....some amps have it..some dont) but radioshack should have you covered, they even hav it in "monster cable"
~tesh
~tesh
ok so then i hook the head unit to one amp and then hook the amps together via the RCAs? or are both amps connected to the head unit?
amp---\ HU or amp-amp>HU this is what im lost on. oh and can someone give me a pic possibly?
amp---/
amp---/
head unit>====>amp>====>amp
thats if one of the amps has rca inputs and outputs
amp<====<headunit>====>amp
via rca splitter
http://www.radioshack.com/product.as...t%5Fid=274-511
(you will need 2 of these unless you can find one that has 2 inputs and 4 outputs...thats just the first one i came across)
via rca splitter
Originally Posted by SCI_TC_GUY
head unit====<Y plug>===both amps
have one set coming from the headunit.....the Y will turn one plug of the rca cable into 2 plugs.....
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
umnitza
Aug 21, 2015 12:35 AM
