Scion FR-S Forum - The Scion sport coupe
Premium fuel?
Old Oct 17, 2012 | 07:26 AM
sciontC's Avatar
DeepSouth Scions
Default Premium fuel?
I knew since this car first came out that it took premium, but I was reading an article that had clips from the owners manual that says that 93 octane was "recommended" and did not use the words "required" like I have seen talking about other cars. Im kind of surprised that this car would require premium, and out of fear of not getting a reliable answer from a salesman at the dealer, id hold you guys opinions higher.
So is premium absolutely a necessity, or are you just losing a little performance? I get why you would need it in a s/c or t/c car but I do not understand why its a necessity in a 2 liter 4 cyl 200 hp car?
Old Oct 17, 2012 | 07:38 AM
frankiietc's Avatar
Because the compression rate is at 12:5:1, to prevent detonation..High compression engines should always have premium..
Old Oct 17, 2012 | 07:19 PM
BrokenTusk's Avatar
100%, higher compression ratio is the reason for the higher octane requirement.
Old Oct 17, 2012 | 10:23 PM
highvoltage1's Avatar
Well some areas dont have 93. Some places have 87,89,91. So thats why it says recommended. But always use the highest you can get.
Old Mar 11, 2013 | 07:50 PM
mikem53's Avatar
You should use premium.. however.. all modern cars have knock sensors that will detect detonation and retard timing.. This will reduce power and protect the engine.. Use premium and drive it like it was intended.
Old Mar 12, 2013 | 12:44 AM
SquallLHeart's Avatar
indeed... some states don't have 93... which is unfortunate because of potential problems.. it's still best to run premium.. even if it's only 91.
the car doesn't like anything less. it really doesn't. it'll hate you... mock you.. and drive horribly.
Old Oct 5, 2013 | 04:57 PM
matc1's Avatar
i run shell v power 91 in toronto car loves it.
Old Oct 6, 2013 | 05:51 AM
KILLER's Avatar
PREMIUM 93oct on all my cars even on my wifes Corolla. On the long run the car will thank you.
I see it as a person eating McDonalds on a regular as to a person who eats healthy.
I always do some math when i see the gas prices. in my area the gas is $3.85 for Premium.
Example:
$3.85x 12 GALLONS = $46.20
$3.62x 12 GALLONS = $43.44
its just a $2.76 difference, why not go the whole way???
Old Oct 12, 2013 | 12:54 PM
whaap's Avatar
91 works fine for me.
Old Nov 13, 2013 | 03:10 PM
subwaynm's Avatar
I will use Premium in my new FR-S; I even use that in my Tacoma and my 73' Super Beetle. On top of which the Octane in New Mexico is slightly lower in grade than AZ where I once was.
Old Nov 18, 2013 | 09:55 AM
whaap's Avatar
91 is all that's available for me. 13,000 miles and my car runs just fine.
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
