Scion tC 2G Forced Induction Turbo and supercharger applications
Custom Turbo kit???
Old Nov 24, 2012 | 09:27 AM
motoxxx87's Avatar
Lightbulb Custom Turbo kit???
So my buddy has a 2011 Scion tC and he want's to go turbo. My question is has any one tried taking a 2010 Turbonetics kit and used it on a 2011? I think the manifolds? I'm hoping the MAP sensor flange is the same as well. I think I can doctor up the IC piping to fit. Then ill do a custom down pipe and open dump right off the wastegate aslo a custom 3" S-pipe back to 2.5 exhaust.
Turbonetics kit
First concern the Slave line might need to bend or get a fitting
Custom Turbo kit???-009.jpg Ptunning kit
Second concern
Custom Turbo kit???-overall.jpg The electrical in the way of the intake
Custom Turbo kit???-intake.jpg The intake will need shortened looks like 8in
Old Nov 24, 2012 | 09:30 AM
motoxxx87's Avatar
Third and finial hopefully concern
Custom Turbo kit???-water.jpg Water return hose might be in the way
Thanks and let me know what you think...
Old Nov 24, 2012 | 08:20 PM
o TaGGeD o's Avatar
Fingers crossed that we can do this man
Old Nov 24, 2012 | 09:58 PM
fosforito04's Avatar
I do that I buy a turbo kit for tc1 and i have a tc2 and he's gone to had a lot of problems
Old Nov 24, 2012 | 10:51 PM
o TaGGeD o's Avatar
You did it?
Old Nov 25, 2012 | 01:21 AM
motoxxx87's Avatar
Can you explain a little more its easy to say you'll have problems tell me were???
Old Nov 26, 2012 | 01:56 AM
the turbo manifold was the most problem I have
secon you have to make a custom intercooler piping
you have to make a custom turbo manifold witch the turbo you have I put a Garrett 6360
Old Nov 26, 2012 | 01:58 AM
I recommend to buy a Full Kit to the tc2 because it bring all plug and play you don't have to waste time
Old Nov 26, 2012 | 05:19 AM
o TaGGeD o's Avatar
Rather waste time than money
Old Nov 26, 2012 | 05:34 AM
motoxxx87's Avatar
Why doesn't the manifold fit the rear flanges look the same...?
Also is the MAF senor the same on 2010 as 2011?
I know there's going to be a few problems with the IC piping from the 1gen but ill use what i can and cut and add couplers to make it work.
Also if you could post any pic that would be very helpful!!!
Were going to use a TURBONETICS Turbo
MODEL: TN 500
COMP WHEEL: 60-1
COMP. INLET /OUTLET: 4.00" / 2.50"
TURBINE WHEEL: F1-62
TRUBINE HOUSING STYLE: T3 .85 AR
TURBINE HOUSING INLET /OUTLET: 4 BOLT / 4 BOLT
P/N: 11517
N0TES : 60 SERIES COVER COVER
[QUOTE=fosforito04;4071940]the turbo manifold was the most problem I have
you have to make a custom turbo manifold witch the turbo you have I put a Garrett 6360[/QUOT
Old Nov 27, 2012 | 04:11 PM
paul_dezod's Avatar
Scionetics
KAD
head flanges are not the same and won't work on the TC1 to TC2. Save yourself time and effort.
Old Nov 27, 2012 | 04:45 PM
draxcaliber's Avatar
this is what you need to understand, cheap turbo kits have a great tendency to turn into expensive turbo kits very easily. Just save up and get a proper kit.
Old Nov 27, 2012 | 04:50 PM
motoxxx87's Avatar
Yeah but iv done a couple now and have a idea of what I'm doing, and iv saved a lot of money.
Old Nov 30, 2012 | 08:19 PM
paul_dezod's Avatar
Scionetics
KAD
Then continue to save and do it right the first time. End of story.
Old Dec 1, 2012 | 05:55 AM
motoxxx87's Avatar
Oh I will like the $3,000 dollar water intercooler kit for the S/C lol
Old Dec 1, 2012 | 06:56 AM
motoxxx87's Avatar
Its so easy to say just buy the already made kit that's not why I started these thread! I want ideas and help if your thoughts are buy a permade kit then keep them to yourself. I want to make something myself and have something different! I want to better his car for the cheapest cost witch I know I can do.
Old Dec 1, 2012 | 07:40 AM
motoxxx87's Avatar
UPDATE ruff idea and pricing
TURBO $680.00
http://www.ebay.com/itm/160870089810...84.m1438.l2649
Manifold $125.00 Might go custom or use Turbonetics used. Going to check exhaust gaskets the tC1 to the tC2 and see if the exhaust ports are the same. If they are I will just drill holes in the tC1 manifold so the studs line up.
http://www.ebay.com/itm/270799041613...84.m1438.l2649
I/C piping $435.00 witch I plan to buy used as well
http://www.ebay.com/itm/160522029610...84.m1438.l2649
Need MAF Sensor Flange $30.00
Intercooler $60.00 aslo most likely going to get used http://www.ebay.com/itm/300821008593...84.m1438.l2649
PNP 550cc Injectors Deatsch $380.00
http://www.ebay.com/itm/360509290019...84.m1438.l2649
Bov HKS $60.00 also buying used
http://www.ebay.com/itm/321029177330...84.m1438.l2649
Wastegate $195.00 also used
http://www.ebay.com/itm/110980052916...84.m1438.l2649
Seeing as we have a friend at a welding shop going to make our own S-pipe and down pipe
Downpipe flange top $20.00
http://www.ebay.com/itm/321024315162...84.m1438.l2649
Downpipe Gasket top $20.00
http://www.ebay.com/itm/230615038933...84.m1438.l2649
Downpipe bottom flange $10.00
http://www.ebay.com/itm/310338276047...84.m1438.l2649
S-pipe flange top (3in) $15.00
http://www.ebay.com/itm/140864809336...84.m1438.l2649
S-pipe bottom gasket is the stock donut gasket $0 LOL
S-pipe bottom flange $20.00
http://www.ebay.com/itm/180128363337...84.m1438.l2649
My S-pipe bottom gasket (3in) $8.00 not attached
One Sick of exhaust pipe 2.5in $35.00 not attached we can get from exhaust shop
One Stick of exhaust pipe 3in $35.00 not attached we can get from exhaust shop
Vacuum Block $25.00
http://www.ebay.com/itm/170911488288...84.m1438.l2649
Oil feed line $28.00
http://www.ebay.com/itm/120458948221...84.m1438.l2649
OEM oil pan gasket at $30.00 not attached
AEM FIC USED $250.00 not attached
AEM P&N Harness $475.00
http://www.customcarscentral.com/bms...c--11-up-.html
A Pillar $75.00
http://www.ebay.com/itm/121014842233...84.m1438.l2649
AEM Wideband $160.00
http://www.ebay.com/itm/230829809245...84.m1438.l2649
Boost gauge $30.00
http://www.ebay.com/itm/400336494854...84.m1438.l2649
Oil Pressure gauge $30.00
http://www.ebay.com/itm/251182254432...84.m1438.l2649
Boost controller $70.00
http://www.ebay.com/itm/390501657019...84.m1438.l2649
So ruffly with new parts I'm looking at $3,500.00 but I'm planning on using mostly used parts
Old Dec 1, 2012 | 05:10 PM
CementTC's Avatar
Would be nice if you can get everything at that price and they are in good condition would save yourself around $1000 but only thing i like about the premade kits are the warranties they come with.
Old Dec 1, 2012 | 05:25 PM
motoxxx87's Avatar
Well the kits new are $4,800 by the time you buy wideband and gauges and stuff your looking at about $5400. So by doing it these way I figure ill be ruffly be saving around $2500 but I think it will be more. The turbo comes with a warrant and that's the only one I really care about.
Old Dec 1, 2012 | 11:29 PM
ashtc2's Avatar
How about a used tc2 turbo kit smart one.
