Scion iQ ICE & Interior In-car entertainment and electronics...
Upgrading the "Big 3"
Old Dec 6, 2012 | 03:02 AM
surfcitylocal's Avatar
Default Upgrading the "Big 3"
I'm getting ready for the new audio system installation so I decided it was time to upgrade the "Big Three". I ran 0 gauge wire from the alternator to the battery and from the negative battery post to the engine and body ground points. The stock Scion wire is really small and doesn't allow for as much current to be passed as I'll need with all the amps installed. By adding the 0 gauge wire it gives a much larger path for the power to run through. My grounding point is also a more solid point than the stock location. From the factory the ground lead connects to a bridge piece above the strut on the driver side. It has to rely on the strength of the weld to flow to the body. I used a grounding point that is on the main body and makes contact directly without any welds. This will provide a path with my less resistance than the stock.
Here are pictures of the stock wire connections...
The alternator...
The body ground...
And the engine block (this location is fine and is where I connected my new 0 gauge wire)...
Some of the tools required to solder the new 0 gauge connectors to the wires...
The new 0 gauge wire from the alternator to the battery...
The new 0 gauge ground wire from the battery to the strut tower...
And the completed project...
I've done this to several of my cars that have had high performance audio systems and it really makes a big difference. More power to the amps means better sound and no dimming of the headlights.
Old Dec 16, 2012 | 03:03 AM
francescorogano's Avatar
Where did u buy the intake from?
Sent from my LG-LS970 using Tapatalk 2
Old Dec 16, 2012 | 05:21 PM
You can find it from DC Sports
www.dcsports.com
KiwiDB
Scion tC 1G ICE & Interior
Sep 15, 2015 02:28 PM
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
reagan9000
Jan 28, 2015 06:20 PM
scioninla
14
Oct 18, 2003 03:46 AM
