'08 HID fog light problem..I need help
Old Feb 14, 2013 | 12:15 AM
1gscionz's Avatar
Default '08 HID fog light problem..I need help
Ok, I know it was a mistake to buy on Ebay first of all, but I already spent the money lol. I bought an HID front vent fog light kit from Motor Energy a while back and I still can't get them to work.
I have my toggle switch power spliced into the ignition wire, and that is connected through the firewall to a relay, which will click on and off so I know the toggle switch and relay are working properly. From the relay I have 4 wires, the toggle switch wire, the ground wire (which is grounded at the factory ground in the driver wheel well), the hot wire (connected to the battery), and the wire that connects both of the fogs to the relay.
I have the front right units ground wire connected to the front left units ground wire, which are then grounded to the factory ground in the wheel well.
Individually, if I press the hot and ground from each unit directly to the leads on the battery they work perfectly. Once I hook them together and connect them to the relay they do not work at all....I have checked over all my connections several times to make sure nothing is loose. all the grounds are solid and the hot to the battery is solid, but nothing seems to work. Will I have to ground the units wires separately? I figured connecting them together and grounding them would do the same thing un-hindered. I had also thought it was a bad relay, until my new one came in the mail and I connected it only to find the same problem . It's like the power just isn't being sent to the fogs at all!!
Any advice would be appreciated!
Thanks
Old Feb 14, 2013 | 02:04 PM
Tc2009luv's Avatar
Big Sky Scion
The only mistake you made was not getting spec D, eBay is actually very legit if you aren't the idiot who just buys on looks not reading the detail and description. Not saying you are . Anyways I went with spec D projector headlights and got a bundle w/ their fog lights for 190 on eBay and free shipping!
Sent from my iPhone using Tapatalk
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
scsteven
Jan 25, 2015 01:06 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
umnitza
Dec 1, 2014 06:26 PM
