Another Easy Way To Clear Your Corners
Old Apr 8, 2005 | 06:24 AM
Eddieg's Avatar
Default Another Easy Way To Clear Your Corners
Well I cleared my corners a couple of weeks ago. Frist off you do not need to unscrew all the bolts that are mentioned in the original post. Just the two that are on the front underside of you fenders, the little palstic "rivets"(?) that hold the grill in, and then the headlight bolts.
WHen I got the headlights out I just did not have the ***** to smash my light with a hammer and a screwdriver....so I took a handheld weed puller, you know the one with the two metal forks on the end. I heated the weed puller on my stove (open flame) until the forks were orange (about 5 minutes). I then inserted it into the headlight and into the amber plastic. It goes through like butter. Did both headlights at the same time, then run the puller under cold water. Reinserted the fork into the headlight through the holes that I burnt into the amber plastic. Lifted up and out. The lens comes out in almost one peice. Then take small long needle nose plires and pick up the amber lens and turn it into the clear part of the headlight, until all the peices are small enough to fall out. It takes half the time and you do not scratch the silver part of your headlights. Hope this helps those who want to clear there corners but have been afriad to smash a hammer and screwdriver into them.
Old Apr 8, 2005 | 07:39 AM
xBino's Avatar
Good to know there's alternatives to the hammer
Old Apr 8, 2005 | 07:58 AM
aireck's Avatar
sweet.. new ideas replacing old methods...
EVOLUTION
Old Apr 8, 2005 | 09:17 AM
fsr20det's Avatar
that is dope. good tip, but i don't have a gas stove.lol
Old Apr 8, 2005 | 10:40 AM
TheIcon's Avatar
I dunno but I think it took more ***** going into your headlight with a hot iron poker. I would be afraid my hand would shake and I would have a melted headlight. Or I could see a bug flying in my nose and there goes my headlight
I guess what matters is you got the job done and nothing was harmed so props for that.
Old Apr 8, 2005 | 01:07 PM
Fujiz_xb's Avatar
sIcKsCiOnS
ill clear them after i get new headlights..so if i mess up i have an extra set.
Old Apr 8, 2005 | 09:28 PM
TheDanger's Avatar
I cleared my headlights the old way but need to do my girlfriends so I might try this method.
Old Apr 8, 2005 | 11:54 PM
sexyscionlover's Avatar
o come on Fuji be daring... no need for an extra set
the hardest part is getting the last amber piece outta there if u dont get it all cracked on the first try. it took me 4 hours to do this mod
half hour getting bumper off
half hour getting headlights outta there
half hour of watching tv and getting the stuff i needed
half hour to break and clean out the one light
hour and a half trying to get amber out of the stubborn one and cleaning headlight
half hour putting everything back on the car and bolting back up
= 4 hours
id be too afraid to use a hot poker. id be afraid id melt the amber reflector, and itd drip inside the light, and solidify there.
Scott
Old Apr 9, 2005 | 12:16 AM
randode's Avatar
Wagonistas
weed puller?
would Roundup work if a weed puller is not available?
Old Apr 9, 2005 | 12:20 AM
squirrel's Avatar
Originally Posted by randode
weed puller?
Old Apr 9, 2005 | 01:51 AM
XbbbbBox's Avatar
Way to be creative!!! Thats what I call thinking outside the BOX!
timinaz's Avatar
That's what I did, now I have a set of Dual Halos and a set of cleared lights...
Old Oct 4, 2005 | 08:21 PM
LouKY05XB's Avatar
man i want to do this but am not sure i have the kahones
Old Jan 8, 2006 | 02:34 AM
80064's Avatar
I tried the hot poker method. I had a broken headlight and it works great. Thanks for that great information!!
Old Jan 8, 2006 | 03:05 AM
Rider's Avatar
Wow that's really something new! Never tought!
I think that's the kind of thing we should see moore often in here! Great job Eddieg!
Eric
Old Jan 8, 2006 | 04:59 AM
mile_hi_sci's Avatar
4 HOURS!? i cleared my headlights in about 45 minutes, from bumper removal to bumper installation with the smash method...you can see pictures in my profile no scratches!!! its easy G!
Old Jan 8, 2006 | 04:56 PM
LouKY05XB's Avatar
yea i got mine done in this amount of time..........and got every peice out tabs and all and i "busted" them out
Old Jan 8, 2006 | 06:50 PM
OdBox's Avatar
How did you guys take out the pieces that were lodged in there?
Old Jan 8, 2006 | 07:03 PM
LouKY05XB's Avatar
bust them with a screwdriver is what i did
Old Jan 8, 2006 | 07:04 PM
LouKY05XB's Avatar
