What Tire Size Do You Recommend for tC on 18x8.5 35mm Offset
Old Apr 11, 2005 | 04:36 PM
Marshall's Avatar
Default What Tire Size Do You Recommend for tC on 18x8.5 35mm Offset
What Tire Size Do You Recommend for a tC on 18x8.5 Rims +35mm offset
I have TRD Springs\Struts (lowered about 1.25")
I couldn't find a definite answer from searching so I was hoping of finding more current information.
I want to get the Perelli PZero Nero M&S
I was going to get 225-40-18 sized tires.
However, I spoke with the dealer at Wheels Direct Online and he recommended that i go 235-40-18 for the tC because it might offer more protection around the lip.
Is anyone running a similar setup, and would I experience any rubbing if I went with the slightly larger 235-40-18?
What tire size would you recommend for a balanced smooth performance ride?
__________________
Old Apr 11, 2005 | 10:27 PM
-Keith-'s Avatar
225/40/18 us what im running with teh same setup
Old Apr 12, 2005 | 03:15 PM
SupaWhiteTc's Avatar
I would go with 245's. I am running 235/35/19's on 19X8.5" w/ 35mm offset.
Old Apr 12, 2005 | 03:52 PM
shane_reid's Avatar
DelMarVa
When changing total diameter of wheel/tire from stock (24.6") make sure you visit:
http://www.miata.net/garage/tirecalc.html
to calculate the differences and also what the experienced Speedo change will be. Whenever you change revs/mile on your wheel/tire your speedo will be off by a percentage.
Old Apr 12, 2005 | 04:13 PM
-Keith-'s Avatar
wow 35? stretched look huh?
Old Apr 12, 2005 | 08:18 PM
bBOXD's Avatar
Old Apr 12, 2005 | 08:44 PM
pdrizzle's Avatar
DeepSouth Scions
I'm riding 215/35/18. If you want more sidewall, I'd go with 225/35/18 or 215/40/18; I've heard that people have problems with 225/40/18 and bigger. Just remember, it's easier to ride smaller tires than it is to ride tires that are too big for your wheel well. Also, the closer you are to the stock wheel diameter, the more accurate your speedometer and odometer will be.
Old Apr 14, 2005 | 12:56 AM
Marshall's Avatar
Thanks for your replies, I appreciate the feedback greatly.
Has anyone else heard of problems with the 225/40-18? I wonder why the TRD Scion tC wheels are that size.
Maybe it's the offset on them that keep them from rubbing.
So, would you say that 235/40-18 would "rub" on 18x8.5 (35 offset) rims with 1.25" lowered TRD springs?
__________________
Old Apr 14, 2005 | 02:50 PM
Shouldn't rub.
Kanchi
Scion xB 2nd-Gen Wheel & Tire
68
Nov 23, 2017 11:04 PM
ScionizedRide
Scion tC 1G Wheel & Tire
Mar 7, 2008 01:54 AM
shorberg
Jul 23, 2007 11:34 PM
Short_Bus
10
Nov 10, 2005 09:27 AM
Male_Nurse
Sep 27, 2003 10:59 AM
