AEM CAI, whistling noise at 60MPH and above
Old Apr 12, 2005 | 12:48 AM
MarkM's Avatar
Default AEM CAI, whistling noise at 60MPH and above
Is anyone else experiencing this? My car only has 1,500 miles. But right after the installation of the CAI, there is a loud whistling noise at 60MPH and above. Can't figure out where it is coming from, but I believe it is from the CAI. Any ideas?
Old Apr 12, 2005 | 01:22 AM
Newtmaker's Avatar
Sounds like a vacuum leak to me.
Walt
Old Apr 12, 2005 | 07:31 AM
B2FiNiTY's Avatar
Is it based on throttle position or does it happen all the time?
Old Apr 12, 2005 | 04:15 PM
mattxb's Avatar
Isn't it true that intakes are inherently noisey/whinny?
Old Apr 12, 2005 | 05:01 PM
MarkM's Avatar
Default Whistling
The noise is not the normal noise that a CAI will make. There is a loud whistling noise coming from the lower front left hand side of the car. Throttle position doesn't make a difference, I can shift into neutral and the noise will still be present. When I hit 60MPH the whistling starts and it is very loud. Sounds like a person blowing across the top of a beer bottle.
Old Apr 12, 2005 | 05:24 PM
silly_rabbit's Avatar
Sounds like one of the pipe isn't inserted enough into either the air-bypass valve or the elbow join. I would suggest loosening the bracket and re-inserting both ends of the pipes are fitted in as far as possible into the Air- bypass valve and the brackets are on tight enough, Do the same with the elbow joint.
Old Apr 13, 2005 | 05:37 AM
flowmini98's Avatar
i was getting a whistle form my intake as well mut i have the WEAPON-R sr intake....but mine isnt at or above a certain speed ...it only happens every once in a while and it seems ot be on really windy day that it happens more. i was told its because of the FINS that are on my filter element. ...
Old Apr 13, 2005 | 05:46 AM
tws's Avatar
tws
from my previous experience, a whistling sound was caused by a small imperfection on the plate inside the throttle body.. when I replaced the throttle body I saw a little nick on the edge of the plate that caused a small amount of air to pass by, giving me a nice little whistle at anything but WOT (wide open throttle).
When I replaced the throttle body the sound was gone, and the plate on the new TB was basically perfect.
It wouldn't hurt you to double-check the connection on all of your couplers though.
Old Apr 13, 2005 | 06:57 PM
MarkM's Avatar
I wanted to thank all of you for your responses. I will try all recommendations this weekend and let you all know. The whistling noise is driving me nuts.
Mark
Old Apr 13, 2005 | 09:22 PM
morningman's Avatar
i dont no on my mini van i used to hear a whistleing when goin over 45 and it turned out to be just the glue on the sealing on the windsheald was pealing off causeing a whistleing noise of air coming between the windsheald and the frame
brett561tc
Sep 15, 2015 06:33 AM
Marialzga
Jul 31, 2015 05:38 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
TinmanTC
Jul 12, 2015 07:53 PM
