Getting the O2 sensor off
Old Apr 13, 2005 | 02:31 AM
TCguy8's Avatar
Default Getting the O2 sensor off
Hey, I am thinking about installing some headers to my TC and I notice I have to take the sheild off the stock one. It looks pretty straight forward by taking off the bolts that hold it on the stock headers. But the one thing I can't figure out is how to take off the 02 sensor on this thing too get the sheild completely off. I don't want to to break it or anything. If anyone can help me, it would be much appreicated.
Old Apr 13, 2005 | 02:58 AM
InLikeFlint's Avatar
Follow the wire from the o2 sensor to the connector(by the engine cover) and just unplug it. Slip the heat shield off over the o2.
Old Apr 13, 2005 | 03:46 PM
SupaWhiteTc's Avatar
Go to Autozone and buy a 02 sensor socket and it comes right out. Unless of course yours melts to the manifold like mine and it takes you an hour of work to get it out. It also cost me $205 for a new A/F Ratio sensor!
Old Apr 13, 2005 | 04:15 PM
TCguy8's Avatar
That did the trick, thanks! You guys were very helpful!
Old Apr 13, 2005 | 04:18 PM
TCguy8's Avatar
Hey SupraWhiteTc I have noticed on the list of mods to your car you
have Nology plug wire Conversion. Do you like it or is it not worth the
180 dollars or so?
Old Apr 27, 2005 | 10:37 PM
triplesix's Avatar
I just took my O2 sensor out to install the alpha werks header and just by taking it out of the stock manifold, the threads were destroyed. Now I have to pay $220 for a new one.
NOT HAPPY!
Old Apr 27, 2005 | 11:15 PM
falcon9094's Avatar
rethread it or go to rockauto.com and get one for an 04 camry $96
Old Apr 27, 2005 | 11:33 PM
ScottsdaleTC's Avatar
Everyone should be warned, it is a common problem with the O2 sensor. Mine was off the day before and put back on with no issues, the following day I pulled it off to install my DC header. The O2 was hanging up, sure enough it was stripped, luckily the parts guy at Toyota only hit me up for $135.00.
I believe the issue is when the engine compartment has not fully cooled down. The steel header/cat retains heat and the O2 crappy metal with heat expansion creates this fatal situation of the O2 sensor.
If I was admin I would get with the experts and post a note in the tech/header section on the O2 sensors, at $200 bones it is a definite must need to know
Old Apr 28, 2005 | 12:21 AM
triplesix's Avatar
Is this confirmed to be the EXACT same part?
Old Apr 28, 2005 | 12:25 AM
falcon9094's Avatar
same engine not sure if it is the same part you could ask them, they dont list it for the 05 camry solara or tc
Old Dec 19, 2024 | 11:53 AM
wesk711's Avatar
NOT HAPPY!
Well. At least it didn't strip the threading in the manifold.
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Topfueltom69
Sep 6, 2015 05:25 PM
