TUNE UP
Old May 16, 2005 | 07:42 PM
DunDeal's Avatar
Default TUNE UP
When is it best for a tune up for our cars. for example changeing the tranmission oil, spark plugs etc. My car is at 38,000 miles and I was wondering if it is that time for a tune up.
Any advice will be helpfull
[/quote]
Old May 16, 2005 | 08:49 PM
Tamago's Avatar
my guess is, you're running iridium plugs (correct me people if i'm wrong) so those are good to 100K.. auto tranny? unsure, but on manual i change tranny oil every 10K. might as well and it's easier than an engine oil change..
what does your manual say ?
Old May 16, 2005 | 08:52 PM
TheBlade's Avatar
I only glanced at the 2AZ specs on this sort of stuff once, here's what I remember:
Oil Change (recommended 5k miles, even though I do every 4k)
Trans (I have a std. so I would think auto is like flush every 12k)
coolant (factory says 100k, I would do it around 60k)
Power Steering (only if low or leak, service)
A/C (if you have probs)
Valve lash clearances (I believe are self-adjusting...if not have them re-checked if you headwork done, but should be good for 100k it not 120k miles)
And..
Chk your serpentine every oil change
Timing I believe is Chain...so have timing checked at like 120-150k miles...most chains will only stretch about a degree or two by 150k miles
Old May 16, 2005 | 08:55 PM
TheBlade's Avatar
I forgot:
Air filter --- chk @ oil changes
Fuel filter -- used to say ever 12k miles, with today's fuel...you could easily get away with 50k miles
Zerk fittings (I dont even think the tie-rod ends have them on the tC...anyhow lube jobs should be done every 5k with the oil changes)
And dont forget to check your muffler-bearings and blinker-fluid often
Old May 16, 2005 | 08:58 PM
TheBlade's Avatar
every 10k on a manual? Wow...call me But usually the service times on a manual are ALOT less often then an auto.
I was planning on servicing my manual trans. around 20k miles and swapping to Mobil1 Synthetic like I did in my Escort.
Man every 10k...maybe I'm just really easy on my gears.
Old May 17, 2005 | 12:05 AM
Tamago's Avatar
it's what, 4bucks for a quart of mobil 1? why NOT change it out? it comes out dirty anyway, can't hurt.
and yeah, the xA/b transmission sucks.. gear grinds all the time even when you baby it, so all that metal should leave the transmission on a regular basis lol
Old May 17, 2005 | 12:24 AM
wholeflaffer's Avatar
Sounds like fairly reasonable (if not conservative) service intervals. Thanks...I think I'll transfer these numbers to my brand new vehicle service log.
Originally Posted by Mr. Spock
Don't let him show you what he calls "the Captain's Log"
alexdrummerr30
Sep 8, 2018 12:18 PM
goldtoaster
Sep 25, 2015 04:58 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
Gigs
Sep 15, 2015 03:54 AM
