Rear Sidemarkers
Old May 18, 2005 | 09:53 PM
BigB's Avatar
Default Rear Sidemarkers
How do you remove the factory Sidemarkers? I got some clear UNIVERSAL SIDE MARKERS that i want to throw on.
Old May 18, 2005 | 10:58 PM
squirrel's Avatar
Its easiest to unbolt the rear bumper cover to unbolt the rear side markers. All you need is a 10mm socket and rachet.
Remove the bolt by the rear tires, the ones you see when you open the hatch, and the ones underneath that hold the bumper and rear lip in place. Pull out slightly, and set the whole assembly on a blanket on the ground.
Unplug the wireloom, unplug the light bulb, unbolt the side marker, and re-install.
Of course, if you aren't using a marker for Toyotas, you'll have to "T" tap or slice the wires in place and shrinkwrap them.
Shouldn't take long at all.
If you were in the Bay Area I would be able to help you with it.
HTH.
Old May 18, 2005 | 11:09 PM
BigB's Avatar
cool thanks for the info i seen the bolt you were talking about when i got under the car, it's just hard work around with dirt falling in your eyes LOL. I don't even no if the sidemarkers i got will cover that hole??? Their thinner than the factory ones.
Old May 18, 2005 | 11:54 PM
squirrel's Avatar
Check your PM.
MRE
Feb 16, 2016 11:26 PM
toyotaisme
Jan 10, 2015 10:24 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
umnitza
Dec 1, 2014 06:26 PM
