How do I turn off the CEL ( check engine light)
Old May 23, 2005 | 08:06 PM
urban_assault_XB's Avatar
Default How do I turn off the CEL ( check engine light)
need help turning off the check engine light ....on a tc
Old May 23, 2005 | 08:09 PM
PoizentC's Avatar
what code are you running? did you just install a header? need more info.
Old May 23, 2005 | 08:16 PM
SCI_TC_GUY's Avatar
to turn off the CEL, fix the problem
Old May 23, 2005 | 08:27 PM
I have a customer that wanted an air fuel gauge installed and some one told him that it connects to the oxygen sensor, so he tried on his own to hook it up to the sensor and it triggered the CEL nothings wrong with the car he just needs to reset it and it shouldn't come back on.....
Old May 23, 2005 | 08:32 PM
PoizentC's Avatar
can't you just disconnect the battery and it should reset the ecu?
Old May 23, 2005 | 08:44 PM
mikochu's Avatar
This tutorial should help you out: https://www.scionlife.com/forums/viewtopic.php?t=33062
Old May 23, 2005 | 10:29 PM
Scatman's Avatar
just disconnect the negative side of the battery for about a minute then hook it back up.....gone.
Old May 23, 2005 | 11:13 PM
nycazn79's Avatar
Are you sure it's not the maintence light that comes up if you need an oil change?
You can also get a OBDII to reset the light. I got one to reset my CEL cause of my header until I did the antifowler trick.
Old May 23, 2005 | 11:17 PM
Nexusindustry's Avatar
If you have an Alphawerks header we can get you one of our processors for the ecu at cost...
Victor D.
Nexus Industry
ALphawerks
Old May 24, 2005 | 02:01 AM
thanks thats what I told him I was posting to be sure..
Jordly221
Feb 13, 2019 05:29 PM
daniinpitt
Apr 4, 2015 08:07 PM
Bakoscion46x
Jan 19, 2015 02:39 AM
AdmirN
Jan 5, 2015 10:19 PM
ScionRo
Jan 2, 2015 07:54 PM
