exhuast manifold gasket(header) help.
Old May 28, 2005 | 08:02 PM
kris79's Avatar
Default exhuast manifold gasket(header) help.
when you guys did your header installs is your manifold gasket split in half? mine is in two pieces and i can see gap between the two pieces when bolted to the block i wonder if thats causing the raspyness. and does anyone have a part number fot he gasket .
Old May 28, 2005 | 08:22 PM
RA31925's Avatar
what do you mean split in half? the gasket looks like a donut. so your saying that its cracked in half?
Old May 28, 2005 | 08:26 PM
hahaitzskippy's Avatar
oooooowwwwwwww
u have a cracked header gasket. looks lik you need to replace that. having pressure leak from your headers = no no and super bad. drove it slow and tak it to a shop ASAP!!!!!!!!!!!!!!
you dont wanna risk breaking your engine
Old May 28, 2005 | 08:36 PM
mikochu's Avatar
I wouldn't recommend re-using the gasket. Once it is pressed between the engine and header, it can't be used again. And yes, it splitting into two pieces is normal once it has been pressed.
The part number for the 2AZ is:
P/N 17173-28010
Old May 28, 2005 | 11:19 PM
RA31925's Avatar
are you talking about this?
the gasket that is on the block?
Old May 28, 2005 | 11:21 PM
matty-tC's Avatar
if it's a metal gasket you should be fine to reuse it but not if its split obviously..
besides, a gasket is dirt cheap, why not replace it ;)
Old May 28, 2005 | 11:46 PM
kris79's Avatar
i was to lazy to pick up a new one, and i am talking bout the manifold gasket not the spipe gasket
Old May 28, 2005 | 11:57 PM
matty-tC's Avatar
if its not 100% flush there, you will get a very loud leak. you should be able to tell its leaking though. if you have the car running and have the hood up, you should be able to hear it leaking somewhere
Bmfxtreme
Aug 18, 2015 01:25 AM
scion86
Jul 6, 2015 03:27 PM
my06tc
Jun 25, 2015 12:18 AM
halosinfire
Scion tC 2G Forced Induction
Jun 10, 2015 05:21 PM
sensez
13
Mar 2, 2004 08:23 AM
