Gauges Installed
Old Jun 20, 2005 | 12:31 AM
Newtmaker's Avatar
Default Gauges Installed
Finally got my gauges installed. Many thanks to Bob (fixerofallthings) for all the help.
http://photobucket.com/albums/v699/n...ent=Gauges.jpg
Walt
Old Jun 20, 2005 | 12:37 AM
XBman's Avatar
very nice!
A+
Old Jun 20, 2005 | 03:54 AM
cadaver's Avatar
you wne t with the same gauges im planning on using, only im gonna mount them under the ashtray. are they the electric ones, the 6152 and 6150?
Old Jun 20, 2005 | 04:49 AM
J_A_Trevino's Avatar
looking good bro, eventually im going to get some gauges decided to get H.I.D's instead
Old Jun 20, 2005 | 11:45 AM
Newtmaker's Avatar
Cadaver, the gauges were ordered from JC Whitney and are the Equus brand. They are electric. I noticed that the items on their webpage do not match the stuff in the catalog. I ordered on the web.
Walt
Old Jun 20, 2005 | 12:26 PM
jallamas's Avatar
Newtmaker,
Looks very nice! I also would like to do electric, could you please tell me at what points on the car you hooked these up and did you use adapters for this project.
Thanks
jallamas
Old Jun 20, 2005 | 03:00 PM
Newtmaker's Avatar
The 12vdc , ground, and illumination were connected to the radio harness using those little quick splicers. The two sender unit wires were run through the firewall to the appropriate sender.
One note. The illumination on these gauges cannot be dimmed by the dash illumination pot on the Scions because the dash lights are leds, not incandescant bulbs. The gauge lights are fairly bright but I will just leave them at full intensity for the time being. I may try to change them to leds sometime later.
Walt
Old Jun 20, 2005 | 03:11 PM
fusionscion's Avatar
nice man, arent u kinda mad the guage cluster is black and not white like the other side is?
Old Jun 20, 2005 | 04:53 PM
Newtmaker's Avatar
The pod is supposedly paintable but after I got it installed I really prefer the black. It really doesn't look that out of place with the other side being white. It just seems like an extension of the dash to me.
Walt
Old Jun 20, 2005 | 05:09 PM
jallamas's Avatar
Newtmaker,
Can you tell me where the oil and water sender wires go on the XB? Also can you still use the idiot lights? where did you get the gauge cluster.
Thanks again
jallamas
Old Jun 20, 2005 | 10:19 PM
Newtmaker's Avatar
I ordered the adapters from http://www.scionsport.com/store/
Look under the gauge/adapter category. The one for the oil filter fits between the filter and the block and has 4 holes for mounting sending units. They are all 1/8 x 27 pipe thread fittings which are pretty much standard for a lot of various senders. I found the adapter very high quality material but the plugs provided really had to be tightened pretty good so as not to leak. I would estimate I was tightening them to about 50 ft lbs with an allen head socket.
The water temp sender fits in the upper radiator hose. You have to cut out a piece in the hose about 1" long to make room for the adapter. Naturally, drain the water a little first. If you put the car up on short ramps and take the splash shield off from the bottom, you will see one radiator drain that has a short tube pointing straight down. A bucket will easily catch the fluid so you can reuse it afterwards. It took mw about an hour to do both adapters just taking it easy and making sure all was right. The gauge cluster is available from the same guys at scionsport.com. It fits right on top of the stock A pillar cover, but you do have to first remove the stock cover, mate the two and then replace as a unit. It is also easier to pull away the door moulding where it covers the a pillar first and then replace it last.
Hope all this helps.
Walt
Old Jan 22, 2006 | 02:06 AM
DoWopBx's Avatar
Default Re: Gauges Installed
Walt
Where is the best place to route the wires thru the firewall? I got the same pillar pod and took my dash all apart today, thinking it would be easier to find a place to run the wires thru. There is one large grommet, but I was hesitant to cut that, but may have to.
Old Jan 22, 2006 | 02:43 AM
akbxb's Avatar
looks good bro..whats up with the rims?
my06tc
Jun 25, 2015 12:18 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
