Wiring help.... what to do?
I just recently ordered the edi 6000 component speakers with the nine.2 amp. Sometime in the near future i will be ordering the 13ov2 subwoofer with another nine.2 amp. I want to do all the wiring while i install my component speakers and have it ready for the install of my sub and amp in the future. I was wondering what kind of wiring i would need to buy. I am very new to all this stuff so ANY feedback is appreciated.
Would a 4 Gauge kit work for all that? Would this work? http://www.cardomain.com/item/LITSXPK4DANL
Thanks in advance.
Greg.
Thanks in advance.
Greg.
yes it would all you need for power wise but you will still need RCAs for you audio and good quality speaker wires if your not going to use the factory wires.
hope this helps,
hope this helps,
Thanks for the quick reply...
I was searching through ebay and found this:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Looks good except its missing the RCA Cables and speaker wires.
I'm gonna have about 600 watts rms total w/ my two amps so i think this should work fine.
What do you guys think
well you can do this...just add another $50 you get the RCAs, speaker wires, sub wires and a cap(eventho its just for show)
http://cgi.ebay.com/ws/eBayISAPI.dll...783138616&rd=1
hope this helps,
hope this helps,
Go to Walmart and get a Scosche 4 gauge wiring kit....its around 30 bucks and should include everything you need for two amps. Even has a distribution block.
This should be the only thing you ever buy at Walmart car audio related.
Bag-boy is good on eBay! You should also check out hifisoundconnection on eBay the also have 4 Gauge with the RCA cords. IMO 4 Gauge under 1000 watts is fine. They have Stinger Kits with RCA for around $50.00.
John
John
Anyone actually purhcased a multi amp kit\ that included everything? (speaker wire and RCA?) for under $100? My speakers arive in 3 days and i still haven't found a good kit.
Any help is appreciated.
Thanks in advance.
Greg
Thanks in advance.
Greg
Greg2385,
Go to www.ebay.com, click on Consumer Electronics the click on Cables, Wiring and Kits and you should see plenty. I have given you a few people I have dealt with in the last posting.
John
John
Originally Posted by jallamas
Greg2385,
John
John
So far, these are the best kits i found... tell me what you think.
Brand New - Retails for $112.40 - Stinger Part # SWK4D
Multi-Amp Power Kit For Amplifiers Totaling Up To 1400 Watts
18' Of 4 Gauge Custom PRO Red Power Wire
10' Of 8 Gauge Custom PRO Red Power Wire
10' Of 8 Gauge Custom PRO Black Ground Wire
1- 24kt Gold Plated ANL Fuse Holder With 150 Amp ANL Fuse
1- 24kt Gold Plated 4 To 8 Gauge Power Distribution Block
17' Of Blue 18 Gauge Amplifier Remote Turn-on Wire
10- 7 Inch Wire Ties
Full Assortment Of 24kt Gold Plated Terminals And Hardware
Protective, Snap-in Wire Grommet
2 - 3 Day Delivery Available with Priority Mail
$46.50
Designed for systems up to1200 Watts
This kit includes:
17' 4 Gauge Translucent Blue Primary Wire
3' 4 Gauge Translucent Silver Ground Wire
17' Twisted Pair RCA Interconnects
16' Blue Remote Turn-On Wire
150 AMP ANL Fuse
ANL Open End Fuse Holder
Silver Plated 4 Gauge Ring Terminal (Red)
Silver Plated 4 Gauge Ring Terminal (Black)
Silver Plated 4 Gauge Spade Terminal (Black)
Siver Plated 4 Gauge Spade Terminal (Red)
10 4" Cable Ties
5' Split Loom Tubing
20' Translucent Silver 16 Gauge Speaker Wire
$26.00
EDIT:
Why is there such a price difference on these RCA cables? Which one should i buy if i go with a kit that doesn't include rca cables?
KnuKonceptz Krystal Twisted Pair 4 Channel RCA Cable 4M
$24.99
KnuKonceptz Twisted Pair Triple Shield RCA Cable 4M
$16.99
KnuKonceptz Twisted Blue/Silver RCA Cable 4M
$11.00
RCA CABLES BLUE TWISTED W/ RIGHT ANGLE 12/20ft
$6.50
The first three are 4 meteres long... the last one is 20 ft. long. Which would you recommend?
The first kit from Stinger is good, are you doing 2 amps? I noticed that it had a two output dist box. For less than a 1000 watts 4 gauge is good. The problem with eBay is you get pretty good prices but they rip you off on shipping. I would stick with Stinger, it is a good company.
John
John
Cool! I would do 4 gauge from the battery with a fuse to the connection block then 8 gauge to the amps and ground. I am sure you can daisy chain your amps so the longest the RCA cords will be from the receiver to the back of the car. I would say 12 feet RCA should be OK and the the amp to amp RCA should be a few feet, remember do not go cheap on RCA'S because you want the cleanest signal.
Good Luck
John
Good Luck
John
I was actually thinkin about going with these RCA's
$11.00
$11.00
Please be careful with your wiring!
I've seen too many cars get burned up because of stupid wiring jobs!
Some tips!
DO NOT put the fuse in until everything is DONE!
The exception would be testing prior to putting all your interior back together
DO NOT run wires AROUND grommets!!
They aren't there to look pretty. They keep your wires from
chafing on the metal body, wearing through, shorting, starting
a fire, and turning your care into a nice pile of molten plastic.
DO NOT connect wires that aren't in use yet!
Don't connect power lines or RCAs or anything unless it's
got a start point and end point. Having live power leads to
shorts, having live RCA leads to noise and possible damages.
If you want to have your wires run for future hardware, feel
free, just don't connecting anything, tape them off to something
near by to keep everything nice and happy and in place.
ALWAYS use the recommended fuses. Don't bump up the
fuse rating if you have a problem, SOLVE the problem.
Don't skimp out, cut corners, or just stuff things in. You will
either burn something up, or get so annoid you'll just have
to redo it right later.
If you aren't sure about any of this, get help!
Some tips!
Some tips!
Some tips!
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
