gas mileage sucks?
Old Jun 24, 2005 | 05:33 PM
pearldrummerms's Avatar
Default gas mileage sucks?
Im over two thousand miles on my 05 tC, and i think my gas mileage is terrible. I have been going an estimated 80-90% city driving with the rest highway miles. I recorded my last two full tank miles and i had about 240 miles then about 250 miles with both tanks almost run dry. With the 14.5 gallon size tank this equates to roughly 17 miles per gallon. Now in my eyes, that is terrible for this car, especially with what it is advertised as. Is this a problem and is there anything i can do about it? Any input would be appreciated, thanks.
Old Jun 24, 2005 | 05:38 PM
TCRS1_0's Avatar
OUCH I have been averaging about 26 mpg in city (auto) . Tire pressure might cause a drop in millage but not that much of a drop . Thing I would do is check your tire pressures make sure they inflated to the right pressures , then take it to a dealer . Also depends on traffic situations , if you sitting in traffic bumper to bumper not moving alot and if you put your foot into the gas alot , But even then when I drive hard I still get about 20 mpg . I have also noticed that if I go to gas stations with bad gas I will get poor millage . Try different gas stations , best I know what to tell ya
Old Jun 24, 2005 | 05:59 PM
sciontc_mich's Avatar
Default Re: gas mileage sucks?
yeah i agree with TCRS1.0 .. check your air pressures.. you could even go 2 lbs higher.. it will result in a more firm ride, but your mpg's will go up a bit.. I had the same problem with low mpg's when i got the car.. was down to like 19.. and i have an auto tC.. I tried a different gas station and it went much higher. I have been using Shell gas.. been working great. so maybe if you can, try shell in a tank and see what happens.
If you're still getting bad fuel economy after trying shell and putting 2lbs of air more into the tires.. then see the dealer, the wheel alignment could be out causing a drag and thus causing bad fuel economy..
Old Jun 24, 2005 | 06:00 PM
Wow, i would kill for that mileage. Well im not sitting in any traffic, tire pressure seems alright, and i switch between gas stations. I mostly use Exxon and Hess. I need to do something about this.
Old Jun 24, 2005 | 06:01 PM
TheScionicMan's Avatar
Are you keeping track of how much gas you are putting in or are you basing your math on the tank size?
Old Jun 24, 2005 | 06:02 PM
engifineer's Avatar
It is advertised as 19-22 in the city. The gearing is what kills it.. It would not perform near as well if they geared it to get better mileage.
Old Jun 24, 2005 | 06:03 PM
engifineer's Avatar
That is also a good point. When the light comes on, or even when it is on the empty mark you still have a couple of gallons or so in the tank. So if you are calculating from there then it comes out to about 20 mpg, which is dead on for the city.
Old Jun 24, 2005 | 06:07 PM
jmiller20874's Avatar
Agreed. Even if you are taking it well below the "R", you are still maybe only adding 12 gallons when you fill up. 250miles/12gals = 21mpg, which is pretty good for city driving and also if you have your AC running.
Hell, one time I ran my car until the needle was over the light and the car still had 1 gallon left when I filled it up.
Old Jun 24, 2005 | 06:09 PM
matt_a's Avatar
...I recorded my last two full tank miles and i had about 240 miles then about 250 miles with both tanks almost run dry. With the 14.5 gallon size tank this equates to roughly 17 miles per gallon.
I think the biggest problem here is the way you are calculating your mileage. You can't just drive until you think you're almost empty, and then go by the size of your tank. You could still have as much as 3 gallons in there, and that will change the figures quite a bit.
Try doing it like this:
-Fill your tank all the way up. Try to remember how you "topped it off". like: Was it two extra squeezes after the first time the pump clicked off?
-After filling the tank, zero out your trip odometer before you pull away from the pump.
-drive as you normally would untill your tank is down to about 1/4 or less (no need to run it dry).
-go back and fill it up again using the same method as in step one.
-now, see how many gallons it took to refill the tank. Also, see how many miles you've driven since the last fill up (on the trip odo). Devide the number of miles by the gallons.
Example: If you drove 275 miles and it took 11 gallons to top it off, you averaged 25 miles per gallon.
Old Jun 24, 2005 | 06:10 PM
Heliotropic's Avatar
Maybe its from toting those drums around town.. j/k
off subject, but do you have any trouble carrying around your kit in your tC? i haven't attempted mine yet.
Old Jun 24, 2005 | 06:11 PM
maximus96's Avatar
i average about 29-30 but i drive 90-95% freeway. i'm very happy with the numbers considering how high it revs in freeway speeds. i drive around 80 usually and it hovers just around 4000 rpm.
Old Jun 24, 2005 | 06:12 PM
engifineer's Avatar
And even calculating it right you should do this about 10 times under similar driving conditions and take an average. The mileage is figured at about 19 - 22 mpg average. It will not be the same every time. May be 25 mpg sometimes, may be 17 others.
TCRS1_0's Avatar
I also noticed with mine if I keep the rpms below 3 K my gas millage is the best (auto) . Trust me it takes a while cuz I still like to bury my foot into it from time to time
Old Jun 24, 2005 | 06:13 PM
PRODIGY3000's Avatar
Gas mileage is always going to suck ___ if you combine mostly stop and go city driving with regular octane (which is what I'm assuming you're using with that abhorrent mpg). Save up and throw in a tank of 93 octane and you'll see a huge difference.
The tC gas guage is a weird one. You can go 50-75 miles (maybe more) before the needle even moves. Then once it begins to drop, it moves quick. Weird.
Old Jun 24, 2005 | 06:14 PM
Not again, for the last time...higher octane does not increase your mileage. But whatever, it's your money.
Old Jun 24, 2005 | 06:18 PM
matt_a's Avatar
Ummm...no, you wont.
engifineer's Avatar
There is a small difference due to more confined (in a time sense) combustion, but it is far from huge. Maybe a few miles per tank at the most. And measuring that is hard since mileage can fluctuate much more than that.
Old Jun 24, 2005 | 06:24 PM
I drive about 80 percent highway. From Palm Beach to the Keys every weekend. I see a difference. Got 390 miles out of a tank once.
Old Jun 24, 2005 | 06:28 PM
Out of how many gallons?
Old Jun 24, 2005 | 06:32 PM
engifineer's Avatar
That can happen with any gas in the car, that is why they rate it AVERAGE mpg. You will see some pretty big fluctuations from the average. I have seen between 25 - 35 on the highway in mine.
