Final Drive
It has been brought to my attention that the Scions in the states have a 4.31:1 final drive in the transmission, were as my Echo Hatch has a 3.72:1 final drive.
Can anyone verify this, and if they can, where can I get a Scion tranny?
Your best bet is to check with a used parts dealer who has a nationwide hookup with many others dealers. He will be able to locate one and even arrainge transportation if necessary.
Walt
Walt
i verified the gear ratios over the weekend.
and this is for the manual transmission.
scion 4.31
echo 3.52 in the sedan
also for ref.
https://www.scionlife.com/forums/viewtopic.php?t=39360
scion 4.31
also for ref.
Raven, just check the yellow pages and see who has the biggest ad under the used auto parts. Give them a call. Almost all the reputable dealers who have been in business for a long time can offer this type service.
Walt
Walt
Also, I just did a Google search on "Used Auto Parts" and got a gazillion hits on places that have nationwide service. I plugged in an xb radio and got a dozen hits on just the first site listed.
Walt
Walt
bad news guys. I went to my Toyota dealership today to do some parts checking.
My echo hatch diff gear part number is 41221-10181, the same as a CDM 2002 Sedan....
Does this mean I have the 3.52, or the 3.71?
Is their anyway to check with my tire height and dyno chart?
The good news is that the Scion part number is different (41221-12340) so, there is some truth to that statement, but I'm curious about the sedan/hatch now.
You guys are at 4,000 rpm at 130 k?
HOT DAMN thats low gears.
I assumed you counted teeth? Is their anyway to check without taking my tranny apart. I'd love to help you whatever way I can Dave.
i'll tell you what Final you have....(most likely you have the 3.52 )
what year is your hatch 2004?
i think its the same for both models that year and on...
2000 - 2003 should have the other gears.
and i did count teeth....
Mine is a 2005. at 130 kph I'm turning just over 3000 rpm on the tach. I am driving on 195/55R15's which are about 2% shorter than stock, which shouldn't make that big of an impact.
a 3.52 FD would turm 3522RPM @ 130KPH
a 3.72 FD would turn 3722RPM @ 130KPH
i say you have the 3.52
xB REFERENCE INFO: (previously posted)
Code:
880 * 4.15 * 0.70 = 2556.4 RPM
(rev per mile) * (final ratio) * (top gear ratio) = (engine RPM at 60MPH)
Just using the stock tire size, the differential ratio, and the top gear ratios of
the xB with manual or auto transmission I come out with these figures, plus
or minus maybe 10 RPM...
AUTOMATIC:
2560 RPM @ 60 MPH
2990 RPM @ 70 MPH
MANUAL:
3070 RPM @ 60 MPH
3580 RPM @ 70 MPH
Gear / Ratio C150 5MT U340E 4AT
1st 3.54:1 2.84:1
2nd 1.90:1 1.55:1
3rd 1.31:1 1.00:1
4th 0.96:1 0.70:1
5th 0.81:1 –
Reverse 3.25:1 2.34:1
Final Drive 4.31:1 4.15:1
Stock tire revolutions per mile = ~880 (Varies by tire make, size, wear, etc.)
Originally Posted by Ashe_WCM
Also Check out...http://pressroom.toyota.com/presstxt...5xAxB_tech.pdf
crystaljukebox_com
39
May 14, 2004 04:55 AM
